주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC HD2 Camera Replacement
필요한 것
    1. HTC HD2 Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      댓글 쓰기
    2. HTC HD2 Camera Replacement: 2 단계, 이미지 2개 중 1개 HTC HD2 Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      댓글 쓰기
    1. HTC HD2 Camera Replacement, Midframe: 3 단계, 이미지 2개 중 1개 HTC HD2 Camera Replacement, Midframe: 3 단계, 이미지 2개 중 2개
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      댓글 쓰기
    2. HTC HD2 Camera Replacement: 4 단계, 이미지 2개 중 1개 HTC HD2 Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      댓글 쓰기
    1. HTC HD2 Camera Replacement, Camera: 5 단계, 이미지 3개 중 1개 HTC HD2 Camera Replacement, Camera: 5 단계, 이미지 3개 중 2개 HTC HD2 Camera Replacement, Camera: 5 단계, 이미지 3개 중 3개
      • Disconnect the flash cable from its socket in the bottom of the motherboard.
      • Carefully pull the cable from its groove in the frame, working your way back to the camera.
      댓글 쓰기
    2. HTC HD2 Camera Replacement: 6 단계, 이미지 3개 중 1개 HTC HD2 Camera Replacement: 6 단계, 이미지 3개 중 2개 HTC HD2 Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Pull the camera flash and cover off of the board.
      • You may need to peel back the sticker that sits behind the battery.
      • Work carefully. Excessive force can damage the camera or motherboard.
      댓글 쓰기
    3. HTC HD2 Camera Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Around the camera is a thin shielding. Remove it with tweezers.
      • Using tweezers, remove the primary camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sam Luedloff
회원 가입일: 04/12/11
727 평판
안내서 3개를 작성함
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G55
5 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 46
전체 시간: 8,429
