주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Hero Camera Replacement
필요한 것
  1. HTC Hero Camera Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    댓글 쓰기
  2. HTC Hero Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    댓글 쓰기
  3. HTC Hero Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    댓글 쓰기
  4. HTC Hero Camera Replacement: 4 단계, 이미지 2개 중 1개 HTC Hero Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    댓글 쓰기
  5. HTC Hero Camera Replacement, Camera: 5 단계, 이미지 3개 중 1개 HTC Hero Camera Replacement, Camera: 5 단계, 이미지 3개 중 2개 HTC Hero Camera Replacement, Camera: 5 단계, 이미지 3개 중 3개
    • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
    댓글 쓰기
  6. HTC Hero Camera Replacement: 6 단계, 이미지 2개 중 1개 HTC Hero Camera Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
    댓글 쓰기
  7. HTC Hero Camera Replacement: 7 단계, 이미지 2개 중 1개 HTC Hero Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the released camera enclosure away from the motherboard until it is completely free.
    댓글 쓰기
  8. HTC Hero Camera Replacement: 8 단계, 이미지 2개 중 1개 HTC Hero Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Max Brown
회원 가입일: 01/23/12
139 평판
안내서 4개를 작성함
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G26
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 38
전체 시간: 1,692
