주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Hero Motherboard Replacement
필요한 것
  1. HTC Hero Motherboard Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    댓글 쓰기
  2. HTC Hero Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    댓글 쓰기
  3. HTC Hero Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    댓글 쓰기
  4. HTC Hero Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HTC Hero Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    댓글 쓰기
  5. HTC Hero Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 HTC Hero Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Release the two ribbon cables using a plastic opening tool.
    • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
    댓글 쓰기
  6. HTC Hero Motherboard Replacement: 6 단계, 이미지 2개 중 1개 HTC Hero Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
    댓글 쓰기
  7. HTC Hero Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HTC Hero Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Rosalind Villalvazo
회원 가입일: 01/23/12
100 평판
안내서 2개를 작성함
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G26
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 1,876
