주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Hero Trackball Replacement
필요한 것
  1. HTC Hero Trackball Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    댓글 쓰기
  2. HTC Hero Trackball Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    댓글 쓰기
  3. HTC Hero Trackball Replacement: 3 단계, 이미지 1개 중 1개
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    댓글 쓰기
  4. HTC Hero Trackball Replacement: 4 단계, 이미지 2개 중 1개 HTC Hero Trackball Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    댓글 쓰기
  5. HTC Hero Trackball Replacement, Trackball: 5 단계, 이미지 2개 중 1개 HTC Hero Trackball Replacement, Trackball: 5 단계, 이미지 2개 중 2개
    • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
    댓글 쓰기
  6. HTC Hero Trackball Replacement: 6 단계, 이미지 2개 중 1개 HTC Hero Trackball Replacement: 6 단계, 이미지 2개 중 2개
    • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
    댓글 쓰기
  7. HTC Hero Trackball Replacement: 7 단계, 이미지 2개 중 1개 HTC Hero Trackball Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard from within the front enclosure.
    • Be careful when pulling the ribbons off the motherboard as they may rip or break.
    댓글 쓰기
  8. HTC Hero Trackball Replacement: 8 단계, 이미지 2개 중 1개 HTC Hero Trackball Replacement: 8 단계, 이미지 2개 중 2개
    • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
    댓글 쓰기
  9. HTC Hero Trackball Replacement: 9 단계, 이미지 3개 중 1개 HTC Hero Trackball Replacement: 9 단계, 이미지 3개 중 2개 HTC Hero Trackball Replacement: 9 단계, 이미지 3개 중 3개
    • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
    • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Max Brown
회원 가입일: 01/23/12
139 평판
안내서 4개를 작성함
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G26
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 36
전체 시간: 1,902
