주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Incredible 2 Power Button Replacement
필요한 것
  1. HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 1 단계, 이미지 2개 중 1개 HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 1 단계, 이미지 2개 중 2개
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    댓글 쓰기
  2. HTC Incredible 2 Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the rear panel from the phone.
    댓글 쓰기
  3. HTC Incredible 2 Power Button Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    댓글 쓰기
  4. HTC Incredible 2 Power Button Replacement: 4 단계, 이미지 2개 중 1개 HTC Incredible 2 Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    댓글 쓰기
  5. HTC Incredible 2 Power Button Replacement, SIM Card: 5 단계, 이미지 2개 중 1개 HTC Incredible 2 Power Button Replacement, SIM Card: 5 단계, 이미지 2개 중 2개
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
    댓글 쓰기
  6. HTC Incredible 2 Power Button Replacement: 6 단계, 이미지 2개 중 1개 HTC Incredible 2 Power Button Replacement: 6 단계, 이미지 2개 중 2개
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
    댓글 쓰기
  7. HTC Incredible 2 Power Button Replacement, Mid Panel: 7 단계, 이미지 1개 중 1개
    • Remove the seven 1.42 mm Torx T5 screws
    댓글 쓰기
  8. HTC Incredible 2 Power Button Replacement: 8 단계, 이미지 2개 중 1개 HTC Incredible 2 Power Button Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
    댓글 쓰기
  9. HTC Incredible 2 Power Button Replacement: 9 단계, 이미지 1개 중 1개
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    댓글 쓰기
  10. HTC Incredible 2 Power Button Replacement, Power Button: 10 단계, 이미지 3개 중 1개 HTC Incredible 2 Power Button Replacement, Power Button: 10 단계, 이미지 3개 중 2개 HTC Incredible 2 Power Button Replacement, Power Button: 10 단계, 이미지 3개 중 3개
    • Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Cristian Suarez
회원 가입일: 04/22/14
108 평판
안내서 1개를 작성함
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G53
5 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 16
전체 시간: 1,085
