주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Maple 100 Front Panel Replacement
필요한 것
    1. HTC Maple 100 Front Panel Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • First remove the back cover of your phone to expose the battery.
      댓글 쓰기
    2. HTC Maple 100 Front Panel Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the phone over.
      • Push forward on the battery with your thumb.
      댓글 쓰기
    3. HTC Maple 100 Front Panel Replacement: 3 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement: 3 단계, 이미지 2개 중 2개
      • Take the battery out by lifting it upwards.
      • When reassembling, make sure that the battery contacts match up.
      댓글 쓰기
    1. HTC Maple 100 Front Panel Replacement, Back Panel: 4 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement, Back Panel: 4 단계, 이미지 2개 중 2개
      • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
      댓글 쓰기
    2. HTC Maple 100 Front Panel Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
      댓글 쓰기
    3. HTC Maple 100 Front Panel Replacement: 6 단계, 이미지 3개 중 1개 HTC Maple 100 Front Panel Replacement: 6 단계, 이미지 3개 중 2개 HTC Maple 100 Front Panel Replacement: 6 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool along the seams at different points to it pry the clips off.
      • This may require a bit of force. The USB port cover may fall off in this step.
      댓글 쓰기
    1. HTC Maple 100 Front Panel Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
      • Remove the one 3.3mm Phillips #00 screw.
      댓글 쓰기
    2. HTC Maple 100 Front Panel Replacement: 8 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement: 8 단계, 이미지 2개 중 2개
      • Use your finger or the plastic opening tool to unclip the board.
      • Be aware of the ribbon cable connected to the motherboard inside the phone.
      댓글 쓰기
    3. HTC Maple 100 Front Panel Replacement: 9 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement: 9 단계, 이미지 2개 중 2개
      • Peel off the yellow piece of tape from the phone.
      댓글 쓰기
    4. HTC Maple 100 Front Panel Replacement: 10 단계, 이미지 3개 중 1개 HTC Maple 100 Front Panel Replacement: 10 단계, 이미지 3개 중 2개 HTC Maple 100 Front Panel Replacement: 10 단계, 이미지 3개 중 3개
      • Flip up the retaining flap with your fingernail or a plastic opening tool.
      • Pull on the ribbon cable gently with your fingers.
      댓글 쓰기
    5. HTC Maple 100 Front Panel Replacement: 11 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement: 11 단계, 이미지 2개 중 2개
      • Split apart the motherboard and front panel.
      • Remove the other yellow piece of tape off of the end of the ribbon cable.
      댓글 쓰기
    6. HTC Maple 100 Front Panel Replacement: 12 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement: 12 단계, 이미지 2개 중 2개
      • Gently pull on the ribbon cable to separate the motherboard.
      댓글 쓰기
    1. HTC Maple 100 Front Panel Replacement, Keyboard: 13 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement, Keyboard: 13 단계, 이미지 2개 중 2개
      • Remove the four 1.9 mm Phillips #00 screws.
      댓글 쓰기
    2. HTC Maple 100 Front Panel Replacement: 14 단계, 이미지 1개 중 1개
      • Peel back the tape gently.
      댓글 쓰기
    3. HTC Maple 100 Front Panel Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the board gently.
      댓글 쓰기
    4. HTC Maple 100 Front Panel Replacement: 16 단계, 이미지 2개 중 1개 HTC Maple 100 Front Panel Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the keys carefully.
      댓글 쓰기
    1. HTC Maple 100 Front Panel Replacement, Front Panel: 17 단계, 이미지 3개 중 1개 HTC Maple 100 Front Panel Replacement, Front Panel: 17 단계, 이미지 3개 중 2개 HTC Maple 100 Front Panel Replacement, Front Panel: 17 단계, 이미지 3개 중 3개
      • Using the Plastic Opening Tool, pry out the LCD screen and remove with fingers.
      • Be gentle because the LCD screen is fragile.
      댓글 쓰기
    2. HTC Maple 100 Front Panel Replacement: 18 단계, 이미지 3개 중 1개 HTC Maple 100 Front Panel Replacement: 18 단계, 이미지 3개 중 2개 HTC Maple 100 Front Panel Replacement: 18 단계, 이미지 3개 중 3개
      • Use the Plastic Opening Tool to remove the internal ear speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Justin Culbertson
회원 가입일: 10/11/11
8 평판
안내서 1개를 작성함
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011 회원
CPSU-MANESS-F11S20G29
4 회원들
안내서 63개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 38
전체 시간: 1,065
