주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One M8 Motherboard Replacement
필요한 것
  1. HTC One M8 Motherboard Replacement, SIM Card: 1 단계, 이미지 2개 중 1개 HTC One M8 Motherboard Replacement, SIM Card: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. HTC One M8 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. HTC One M8 Motherboard Replacement, MicroSD Card: 3 단계, 이미지 2개 중 1개 HTC One M8 Motherboard Replacement, MicroSD Card: 3 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. HTC One M8 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. HTC One M8 Motherboard Replacement, Rear Case: 5 단계, 이미지 2개 중 1개 HTC One M8 Motherboard Replacement, Rear Case: 5 단계, 이미지 2개 중 2개
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  6. HTC One M8 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HTC One M8 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HTC One M8 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  7. HTC One M8 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HTC One M8 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  8. HTC One M8 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  9. HTC One M8 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HTC One M8 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HTC One M8 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
  10. HTC One M8 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 HTC One M8 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    • Remove the two silver 2 mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
  11. HTC One M8 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 HTC One M8 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 HTC One M8 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a spudger to disconnect the two (four) antenna cables.
    • Use the tip of a spudger to disconnect the seven ZIF connectors.
    • Use a pair of tweezers to gently pull the seven ribbon cables free of the connectors.
  12. HTC One M8 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove three silver 3mm screws using T5 screwdriver.
  13. HTC One M8 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 HTC One M8 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 HTC One M8 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Use an iOpener or a heat gun to loosen up the adhesive securing the motherboard to the display assembly.
    • Use a plastic opening tool to gently pry the motherboard free of the display assembly.
    • At this point, the bottom speaker is still attached to the motherboard. If you are only replacing the motherboard, refer to the bottom speaker guide to swap your existing speaker to the new motherboard.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Michael Gonzalez
회원 가입일: 04/14/15
4,439 평판
안내서 5개를 작성함
Cal Poly, Team 5-9, Maness Spring 2015 Cal Poly, Team 5-9, Maness Spring 2015 회원
CPSU-MANESS-S15S5G9
4 회원들
안내서 18개를 작성함
2가이드 댓글
Thanks you very much
ngvhiem26 - 답글
all ok. thanks.
Javier - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 39
지난 30일: 135
전체 시간: 26,221
