주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One Max Back Case Replacement
필요한 것
  1. HTC One Max Back Case Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    댓글 쓰기
  2. HTC One Max Back Case Replacement: 2 단계, 이미지 2개 중 1개 HTC One Max Back Case Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    댓글 쓰기
  3. HTC One Max Back Case Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    댓글 쓰기
  4. HTC One Max Back Case Replacement: 4 단계, 이미지 2개 중 1개 HTC One Max Back Case Replacement: 4 단계, 이미지 2개 중 2개
    • Use the small plastic opening tool to pry between the screen and the rear case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Andrew Keller
회원 가입일: 09/23/14
1,131 평판
안내서 5개를 작성함
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G3
4 회원들
안내서 7개를 작성함
5가이드 댓글
any idea where i can purchase that back case?
omair - 답글 공유
The "Tools" section of the guide lists a Y0 screwdriver as required but in the steps it says Y1. Now I have a Y0 screwdriver i can't do anything with and i have to order a Y1. Hopefully that is accurate.
khaydin - 답글 공유
Soooo... unless your HTC One MAX is completely different from the Sprint one i'm trying to replace the back on, both the Y0 and Y1 screw drivers are WRONG for this phone. They are both a bit too big to work on the screws. Now I've bought TWO screw drivers from you guys that were incorrect. Guess i'm gonna need to go out and buy a tri-wing screw driver set.
khaydin - 답글 공유
You need a #Y00 which is smaller then a #Y0 and #Y1 .
Leonturner21 - 답글 공유
The site tells you to use a #Y00 and it does work for any HTC One Max
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 45
전체 시간: 4,427
