주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One Max Motherboard Replacement
필요한 것
    1. HTC One Max Motherboard Replacement, Back Case: 1 단계, 이미지 1개 중 1개
      • Lift back cover while pressing highlighted release switch towards the center of the phone.
      댓글 쓰기
    2. HTC One Max Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HTC One Max Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four white stickers in each corner that cover the Tri-Wing screws.
      • Remove the white sticker near the buttons that control the volume.
      • Remove the white sticker near the SIM card.
      • Remove the big white sticker with the bar-code in the center of the phone.
      댓글 쓰기
    3. HTC One Max Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
      • Disconnect the cable near the volume buttons.
      댓글 쓰기
    4. HTC One Max Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HTC One Max Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Use the small plastic opening tool to pry between the screen and the rear case.
      댓글 쓰기
    1. HTC One Max Motherboard Replacement, Fingerprint Sensor: 5 단계, 이미지 2개 중 1개 HTC One Max Motherboard Replacement, Fingerprint Sensor: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
      • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
      댓글 쓰기
    1. HTC One Max Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 HTC One Max Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
      • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
      • Use a plastic tool to remove the ribbon cable.
      댓글 쓰기
    2. HTC One Max Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HTC One Max Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
      • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
      댓글 쓰기
    3. HTC One Max Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the seven 3 mm Phillips #000 screws from the motherboard.
      댓글 쓰기
    4. HTC One Max Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HTC One Max Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HTC One Max Motherboard Replacement: 9 단계, 이미지 3개 중 3개
      • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
      • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
      댓글 쓰기
    5. HTC One Max Motherboard Replacement: 10 단계, 이미지 3개 중 1개 HTC One Max Motherboard Replacement: 10 단계, 이미지 3개 중 2개 HTC One Max Motherboard Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
      • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
      댓글 쓰기
    6. HTC One Max Motherboard Replacement: 11 단계, 이미지 2개 중 1개 HTC One Max Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Use a plastic tool to lift and remove the motherboard.
      • Use a heat gun to loosen adhesive at bottom if needed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Keller
회원 가입일: 09/23/14
1,131 평판
안내서 5개를 작성함
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G3
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 29
전체 시간: 6,096
