주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One Max Rear Facing Camera Replacement
필요한 것
    1. HTC One Max Rear Facing Camera Replacement, Back Case: 1 단계, 이미지 1개 중 1개
      • Lift back cover while pressing highlighted release switch towards the center of the phone.
      댓글 쓰기
    2. HTC One Max Rear Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four white stickers in each corner that cover the Tri-Wing screws.
      • Remove the white sticker near the buttons that control the volume.
      • Remove the white sticker near the SIM card.
      • Remove the big white sticker with the bar-code in the center of the phone.
      댓글 쓰기
    3. HTC One Max Rear Facing Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
      • Disconnect the cable near the volume buttons.
      댓글 쓰기
    4. HTC One Max Rear Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Use the small plastic opening tool to pry between the screen and the rear case.
      댓글 쓰기
    1. HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: 5 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
      • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
      댓글 쓰기
    1. HTC One Max Rear Facing Camera Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
      • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
      • Use a plastic tool to remove the ribbon cable.
      댓글 쓰기
    2. HTC One Max Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
      • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
      댓글 쓰기
    3. HTC One Max Rear Facing Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the seven 3 mm Phillips #000 screws from the motherboard.
      댓글 쓰기
    4. HTC One Max Rear Facing Camera Replacement: 9 단계, 이미지 3개 중 1개 HTC One Max Rear Facing Camera Replacement: 9 단계, 이미지 3개 중 2개 HTC One Max Rear Facing Camera Replacement: 9 단계, 이미지 3개 중 3개
      • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
      • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
      댓글 쓰기
    5. HTC One Max Rear Facing Camera Replacement: 10 단계, 이미지 3개 중 1개 HTC One Max Rear Facing Camera Replacement: 10 단계, 이미지 3개 중 2개 HTC One Max Rear Facing Camera Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
      • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
      댓글 쓰기
    6. HTC One Max Rear Facing Camera Replacement: 11 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement: 11 단계, 이미지 2개 중 2개
      • Use a plastic tool to lift and remove the motherboard.
      • Use a heat gun to loosen adhesive at bottom if needed.
      댓글 쓰기
    1. HTC One Max Rear Facing Camera Replacement, IR Blaster: 12 단계, 이미지 1개 중 1개
      • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
      댓글 쓰기
    2. HTC One Max Rear Facing Camera Replacement: 13 단계, 이미지 1개 중 1개
      • Pick up and set aside vibrator, do not disconnect.
      댓글 쓰기
    3. HTC One Max Rear Facing Camera Replacement: 14 단계, 이미지 1개 중 1개
      • Pull out ribbon cable.
      • Peel back infrared sensor.
      댓글 쓰기
    1. HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: 15 단계, 이미지 2개 중 1개 HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: 15 단계, 이미지 2개 중 2개
      • Lift the secondary motherboard with the camera attached.
      댓글 쓰기
    2. HTC One Max Rear Facing Camera Replacement: 16 단계, 이미지 3개 중 1개 HTC One Max Rear Facing Camera Replacement: 16 단계, 이미지 3개 중 2개 HTC One Max Rear Facing Camera Replacement: 16 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to disconnect the camera ribbon cable.
      • Remove rear camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Keller
회원 가입일: 09/23/14
1,131 평판
안내서 5개를 작성함
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G3
4 회원들
안내서 35개를 작성함
1가이드 댓글
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
alberto rivera - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 34
전체 시간: 8,532
