주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One Mini Screen Replacement
필요한 것
    1. HTC One Mini Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to remove the bottom speaker cover
      댓글 쓰기
    2. HTC One Mini Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Use your T6 Torx screwdriver to remove the single screw that holds the body to the aluminium back
      댓글 쓰기
    3. HTC One Mini Screen Replacement, This step requires a little patience: 3 단계, 이미지 2개 중 1개 HTC One Mini Screen Replacement, This step requires a little patience: 3 단계, 이미지 2개 중 2개
      • Use only plastic opening tools, metal ones will cause damage to the assembly
      • Use a plastic opening tool next to the usb port to gently lift the bottom away from the backing.
      • Use a second tool to work your way around the phone undoing the clips while the first tool lifts the undone areas
      댓글 쓰기
    4. HTC One Mini Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Use your heat gun and infra-red thermometer to heat the screen assembly to 130 degrees C (265 F) to soften the adhesive
      • Use opening tool to gently lift the edges of the screen away from the body working from the top down.
      • Don't try to remove the bottom of the screen as your flex cables are there and still attached to the logic board
      댓글 쓰기
    5. HTC One Mini Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Undo the 2 Phillips screws circled in red and detach the battery connector (so we don't short anything out)
      • Undo the 3 screws holding down the bottom of the logic board and charger port circled in green
      • Undo the flex cables and speaker power cable circled in blue and lift the charger port out
      • The flex cable for this board and the one next to it for the screen their locking tabs open from the back
      • Gently using a plastic opening tool lift out the bottom speaker
      • Also the rubber spacer circled in blue
      • Undo the flex cables circled in orange and slowly start pulling the old screen out
      댓글 쓰기
    6. HTC One Mini Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Remove any old adhesive and broken glass from the frame
      • Gently feed through the flex cables taking great care not to break them
      • Don't remove any of this sheilding tape, I have only removed it to show you that there is nothing under there and I have replaced it during reassembly
      댓글 쓰기
    7. HTC One Mini Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Fold the screen away from the body keeping in mind not to damage the flex cables.
      • Add your strips of adhesive tape to the frame and put put the screen onto the body (I have highlighted the placement areas in blue)
      • You will have to cut the tape in half for the sides of the screen. Using a razor blade and a metal ruler will give best results.
      • Follow the steps in reverse for reassembly and use a couple of drops of super glue to put the front speaker cover back on
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Robbie
회원 가입일: 07/11/14
655 평판
안내서 1개를 작성함
2가이드 댓글
I just need to change the touch digitizer, how do I detach it from the LCD?
hudeor - 답글 공유
Where can i find a replacement screen
pietro.faraggiana - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 40
전체 시간: 37,516
