주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One X Antenna Replacement
필요한 것
  1. HTC One X Antenna Replacement, Squeeze Test: 1 단계, 이미지 1개 중 1개
    • Before replacement of the antenna, carry out the squeeze test.
    • Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
    • If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
    댓글 쓰기
  2. HTC One X Antenna Replacement, Remove SIM card slot: 2 단계, 이미지 1개 중 1개
    • Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    댓글 쓰기
  3. HTC One X Antenna Replacement, Remove front panel: 3 단계, 이미지 2개 중 1개 HTC One X Antenna Replacement, Remove front panel: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage or bodily harm.
    • Set aside the rear panel for now
    댓글 쓰기
  4. HTC One X Antenna Replacement, Replace antenna: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Once the rear panel is separated from the front panel, remove the antenna using tweezers.
    • The antenna is located on the right hand side of the front panel as indicated in the image.
    • Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Blain Abebe
회원 가입일: 09/22/14
769 평판
안내서 3개를 작성함
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 회원
USFT-BROWN-F14S4G3
3 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 29
전체 시간: 9,814
