주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One X Button Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. HTC One X Button Replacement, Remove SIM card slot: 1 단계, 이미지 1개 중 1개
    • Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    댓글 쓰기
  2. HTC One X Button Replacement, Remove front panel: 2 단계, 이미지 2개 중 1개 HTC One X Button Replacement, Remove front panel: 2 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, carefully separate the display screen from the rear panel.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage.
    • Set aside the rear panel.
    댓글 쓰기
  3. HTC One X Button Replacement, Remove the top plastic panel: 3 단계, 이미지 2개 중 1개 HTC One X Button Replacement, Remove the top plastic panel: 3 단계, 이미지 2개 중 2개
    • Remove the five screws at the top of the panel using a Phillips head screwdriver.
    • Two 2.05mm Philips head screws
    • Three 2.44mm Philips head screws
    • Also remove the screws with the warranty stickers.
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
    • Once you have disassembled your device, your warranty will no longer be valid.
    댓글 쓰기
  4. HTC One X Button Replacement, Remove antenna and disconnect the PCB board: 4 단계, 이미지 2개 중 1개 HTC One X Button Replacement, Remove antenna and disconnect the PCB board: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
    • Two 3.35mm Philips head screws
    • Use tweezers to disconnect the antenna from the logic board to the PCB board.
    • Remove the tape connected to the motherboard.
    댓글 쓰기
  5. HTC One X Button Replacement, Disconnect the battery and remove PCB board: 5 단계, 이미지 3개 중 1개 HTC One X Button Replacement, Disconnect the battery and remove PCB board: 5 단계, 이미지 3개 중 2개 HTC One X Button Replacement, Disconnect the battery and remove PCB board: 5 단계, 이미지 3개 중 3개
    • Remove the tape holding the battery in place.
    • Gently lift the battery from the bottom using a plastic opening tool.
    • You may have to apply heat to melt the glue holding the battery in place.
    • Do not completely remove the battery yet
    • You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
    • Now that it's separated, remove and set aside the PCB board.
    댓글 쓰기
  6. HTC One X Button Replacement, Disconnect flex cables: 6 단계, 이미지 3개 중 1개 HTC One X Button Replacement, Disconnect flex cables: 6 단계, 이미지 3개 중 2개 HTC One X Button Replacement, Disconnect flex cables: 6 단계, 이미지 3개 중 3개
    • Place the battery back into its original position once the PCB board has been removed
    • Use tweezers to disconnect the power button flex cables.
    • Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
    • Disconnect the touchscreen flex cable
    • If repairing hard buttons, skip step 7.
    댓글 쓰기
  7. HTC One X Button Replacement, Remove logic board: 7 단계, 이미지 1개 중 1개
    • Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
    • You may now remove the board safely
    댓글 쓰기
  8. HTC One X Button Replacement, Ensure flex cables and buttons are connected: 8 단계, 이미지 2개 중 1개 HTC One X Button Replacement, Ensure flex cables and buttons are connected: 8 단계, 이미지 2개 중 2개
    • Ensure that the power button flex cable from Step 6 is connected securely with its base.
    • Ensure that the volume flex cable from Step 6 is connected securely with its base.
    • If necessary you may need to replace these flex cables completely.
    • Follow these steps in reverse and specifically check the power and volume buttons as they're placed into the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nyles Peterson
회원 가입일: 09/22/14
1,915 평판
안내서 3개를 작성함
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 회원
USFT-BROWN-F14S4G3
3 회원들
안내서 19개를 작성함
1가이드 댓글
Mera phone htc one x hi jo chalu nahi ho raha hi ab mi kya karu mene phone ko pura khola tha
Abhishek tripathi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 3,014
