주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC SMT 6175 Display Screen Replacement
필요한 것
    1. HTC SMT 6175 Display Screen Replacement, Back Case: 1 단계, 이미지 1개 중 1개
      • First, flip the phone over so that the back is facing upwards.
      댓글 쓰기
    2. HTC SMT 6175 Display Screen Replacement: 2 단계, 이미지 2개 중 1개 HTC SMT 6175 Display Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
      댓글 쓰기
    3. HTC SMT 6175 Display Screen Replacement, Battery: 3 단계, 이미지 2개 중 1개 HTC SMT 6175 Display Screen Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
      댓글 쓰기
    1. HTC SMT 6175 Display Screen Replacement, Interior Back Case: 4 단계, 이미지 2개 중 1개 HTC SMT 6175 Display Screen Replacement, Interior Back Case: 4 단계, 이미지 2개 중 2개
      • To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
      댓글 쓰기
    2. HTC SMT 6175 Display Screen Replacement: 5 단계, 이미지 2개 중 1개 HTC SMT 6175 Display Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Pull off the case.
      • This can be difficult. Just start pulling the back out from the front shell and, as it starts to lift up, continue moving around the phone until the whole back becomes free.
      댓글 쓰기
    3. HTC SMT 6175 Display Screen Replacement, Taking out the Motherboard: 6 단계, 이미지 1개 중 1개
      • Next, unscrew the top screw using a small, Philips screwdriver.
      • Pull back the motherboard.
      • The LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable and to the front case by an adhesive.
      댓글 쓰기
    4. HTC SMT 6175 Display Screen Replacement, Taking out the Display Screen: 7 단계, 이미지 2개 중 1개 HTC SMT 6175 Display Screen Replacement, Taking out the Display Screen: 7 단계, 이미지 2개 중 2개
      • Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
      • The LCD is attached with a sticky adhesive so it might be difficult to get off.
      댓글 쓰기
    5. HTC SMT 6175 Display Screen Replacement: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Place the motherboard down on top of the LCD. Using tweezers, remove the yellow piece of tape covering the end of the flat ribbon cable.
      댓글 쓰기
    6. HTC SMT 6175 Display Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Peel off the silver tape covering the flat ribbon cable. The motherboard is now free from the rest of the phone.
      • The sticky gray tape might have to be ripped in order to be removed because of its extreme stickiness.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Luke Plewa
회원 가입일: 04/22/11
116 평판
안내서 4개를 작성함
Cal Poly, Team 25-29, Garner Spring 2011 Cal Poly, Team 25-29, Garner Spring 2011 회원
CPSU-GARNER-S11S25G29
3 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 2,099
