주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Thunderbolt Motherboard Replacement
필요한 것
  1. HTC Thunderbolt Motherboard Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
    댓글 쓰기
  2. HTC Thunderbolt Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Lift and remove the rear panel.
    댓글 쓰기
  3. HTC Thunderbolt Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
    댓글 쓰기
  4. HTC Thunderbolt Motherboard Replacement, MicroSD Card: 4 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement, MicroSD Card: 4 단계, 이미지 2개 중 2개
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
    댓글 쓰기
  5. HTC Thunderbolt Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
    댓글 쓰기
  6. HTC Thunderbolt Motherboard Replacement, Rear Frame: 6 단계, 이미지 1개 중 1개
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
    댓글 쓰기
  7. HTC Thunderbolt Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
    댓글 쓰기
  8. HTC Thunderbolt Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws where the plastic cover was.
    댓글 쓰기
  9. HTC Thunderbolt Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
    댓글 쓰기
  10. HTC Thunderbolt Motherboard Replacement: 10 단계, 이미지 3개 중 1개 HTC Thunderbolt Motherboard Replacement: 10 단계, 이미지 3개 중 2개 HTC Thunderbolt Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
    댓글 쓰기
  11. HTC Thunderbolt Motherboard Replacement, LCD/Screen: 11 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement, LCD/Screen: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
    댓글 쓰기
  12. HTC Thunderbolt Motherboard Replacement: 12 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
    댓글 쓰기
  13. HTC Thunderbolt Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
    댓글 쓰기
  14. HTC Thunderbolt Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HTC Thunderbolt Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
    댓글 쓰기
  15. HTC Thunderbolt Motherboard Replacement, Motherboard: 15 단계, 이미지 1개 중 1개
    • The motherboard should now be completely disconnected
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Vanessa
회원 가입일: 01/18/13
60 평판
안내서 4개를 작성함
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 회원
CPSU-REGAN-W13S19G45
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 2,121
