주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Touch Pro 2 Display Screen Replacement
필요한 것
    1. HTC Touch Pro 2 Display Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Display Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Display Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Apply pressure and slide upward to remove back cover.
      • Lift the back cover up away from the phone.
      댓글 쓰기
    2. HTC Touch Pro 2 Display Screen Replacement: 2 단계, 이미지 2개 중 1개 HTC Touch Pro 2 Display Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Lift battery upward on the upper right-hand side to remove it.
      • Check the battery to make sure there's no bent corners.
      댓글 쓰기
    1. HTC Touch Pro 2 Display Screen Replacement, Housing: 3 단계, 이미지 2개 중 1개 HTC Touch Pro 2 Display Screen Replacement, Housing: 3 단계, 이미지 2개 중 2개
      • Using a T5 screwdriver, remove the four screws in corners as shown.
      • Lift the top portion of the rear case.
      • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
      댓글 쓰기
    2. HTC Touch Pro 2 Display Screen Replacement: 4 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Display Screen Replacement: 4 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Display Screen Replacement: 4 단계, 이미지 3개 중 3개
      • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
      • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
      • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
      댓글 쓰기
    1. HTC Touch Pro 2 Display Screen Replacement, Display Screen: 5 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Display Screen Replacement, Display Screen: 5 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Display Screen Replacement, Display Screen: 5 단계, 이미지 3개 중 3개
      • Peel the off yellow ribbon slowly.
      • Unscrew the fours screws in red squares (two in each square) using a 00 screwdriver.
      • After the screws are out you will be able to easily take off the small metal pieces.
      댓글 쓰기
    2. HTC Touch Pro 2 Display Screen Replacement: 6 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Display Screen Replacement: 6 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Display Screen Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Gently peel off the yellow tape.
      • Carefully pull the dual black strip off using force.
      • Behind the dual black strip is very sticky piece of grey tape. Use tweezers with a grip at end to peel it off, be careful not to rip the grey tape.
      댓글 쓰기
    3. HTC Touch Pro 2 Display Screen Replacement: 7 단계, 이미지 2개 중 1개 HTC Touch Pro 2 Display Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Lift up the metal hinges up.
      • Lift the keyboard frame off separating the key board from the screen.
      댓글 쓰기
    4. HTC Touch Pro 2 Display Screen Replacement: 8 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Display Screen Replacement: 8 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Display Screen Replacement: 8 단계, 이미지 3개 중 3개
      • Unscrew the two screws shown using a 00 phillips screwdriver.
      • Wedge a flat head screwdriver or metal prying tool between the flat face and rounded edge of the phone casing. Then, slide and pry around the entire piece until the face comes off.
      댓글 쓰기
    5. HTC Touch Pro 2 Display Screen Replacement: 9 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Display Screen Replacement: 9 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Display Screen Replacement: 9 단계, 이미지 3개 중 3개
      • Use a spudger to lift up the three black latches that secure the flat electrical wire. Then, pull the wire out of the latches being careful not to rip them.
      • Carefully, peel the silver electric tape off (force required).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Melinda Phan
회원 가입일: 04/17/11
438 평판
안내서 9개를 작성함
Cal Poly, Team 9-64, Walters Spring 2011 Cal Poly, Team 9-64, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G64
5 회원들
안내서 108개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 41
전체 시간: 12,101
