주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Vive Controller Saucer Replacement
필요한 것
  1. HTC Vive Controller Saucer Replacement, Saucer Panels: 1 단계, 이미지 3개 중 1개 HTC Vive Controller Saucer Replacement, Saucer Panels: 1 단계, 이미지 3개 중 2개 HTC Vive Controller Saucer Replacement, Saucer Panels: 1 단계, 이미지 3개 중 3개
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    댓글 쓰기
  2. HTC Vive Controller Saucer Replacement: 2 단계, 이미지 2개 중 1개 HTC Vive Controller Saucer Replacement: 2 단계, 이미지 2개 중 2개
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    댓글 쓰기
  3. HTC Vive Controller Saucer Replacement: 3 단계, 이미지 2개 중 1개 HTC Vive Controller Saucer Replacement: 3 단계, 이미지 2개 중 2개
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    댓글 쓰기
  4. HTC Vive Controller Saucer Replacement: 4 단계, 이미지 3개 중 1개 HTC Vive Controller Saucer Replacement: 4 단계, 이미지 3개 중 2개 HTC Vive Controller Saucer Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Ryan Grewohl
회원 가입일: 10/02/17
893 평판
안내서 3개를 작성함
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G5
4 회원들
안내서 59개를 작성함
3가이드 댓글
Where do you get the replacement parts?
dmitri.walker - 답글 공유
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - 답글 공유
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 52
전체 시간: 7,279
