주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Wizard 100 Speakers Replacement
필요한 것
    1. HTC Wizard 100 Speakers Replacement, Battery: 1 단계, 이미지 2개 중 1개 HTC Wizard 100 Speakers Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Power the phone off.
      • Use your thumb to gently press downward and away from the camera to remove the battery cover.
      댓글 쓰기
    2. HTC Wizard 100 Speakers Replacement: 2 단계, 이미지 2개 중 1개 HTC Wizard 100 Speakers Replacement: 2 단계, 이미지 2개 중 2개
      • Pull on the plastic tab to release the battery.
      댓글 쓰기
    1. HTC Wizard 100 Speakers Replacement, Back Case: 3 단계, 이미지 2개 중 1개 HTC Wizard 100 Speakers Replacement, Back Case: 3 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to remove the camera cover.
      • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
      • Lift the camera cover off of the phone.
      댓글 쓰기
    2. HTC Wizard 100 Speakers Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the stylus from the phone.
      • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
      • One of the screws might be under a sticker, which will void your warranty.
      댓글 쓰기
    3. HTC Wizard 100 Speakers Replacement: 5 단계, 이미지 3개 중 1개 HTC Wizard 100 Speakers Replacement: 5 단계, 이미지 3개 중 2개 HTC Wizard 100 Speakers Replacement: 5 단계, 이미지 3개 중 3개
      • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
      • If your phone contains a memory card, you may want to remove it before proceeding with this step.
      • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
      • Lift the back case off completely.
      • The speakers might be dangling and unsecured.
      댓글 쓰기
    1. HTC Wizard 100 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 1개 HTC Wizard 100 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 2개
      • Grip the speaker connector with your thumb and finger and gently pull up.
      • Repeat for 2nd speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Taylor Stone
회원 가입일: 10/06/11
45 평판
안내서 2개를 작성함
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 회원
CPSU-MANESS-F11S20G28
4 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 28
전체 시간: 891
