주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC myTouch 3G Glass Screen/LED Display Replacement
필요한 것
  1. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove the Cover: 1 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove the Cover: 1 단계, 이미지 2개 중 2개
    • Press both thumbs on each side of the upper corners, and apply pressure in a downward motion.
    • While applying downward pressure, slide the back cover down and off the phone.
    댓글 쓰기
  2. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Battery and SIM Card: 2 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Battery and SIM Card: 2 단계, 이미지 2개 중 2개
    • Remove the battery.
    • Remove the SIM card.
    댓글 쓰기
  3. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove SD Card: 3 단계, 이미지 1개 중 1개
    • Push the SD card in to eject it.
    • Pull the SD card out.
    댓글 쓰기
  4. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Panel Screws: 4 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Panel Screws: 4 단계, 이미지 2개 중 2개
    • Remove the four 6 mm T5 Torx screws from the four corners on the back of the phone.
    • Remove the two 4 mm T5 Torx screws from the middle of the back of the phone.
    댓글 쓰기
  5. HTC myTouch 3G Glass Screen/LED Display Replacement, Access the Motherboard: 5 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Access the Motherboard: 5 단계, 이미지 2개 중 2개
    • Pull out the antenna cover to access the motherboard.
    댓글 쓰기
  6. HTC myTouch 3G Glass Screen/LED Display Replacement, Dislodge the Back Plate: 6 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Dislodge the Back Plate: 6 단계, 이미지 2개 중 2개
    • Insert a spudger into the gap between the frame and cover. Push downward with the spudger to separate the back plate from the phone.
    • With the spudger in the gap between the frame and cover, move the spudger around the edge of the of the phone to finish removing the back plate.
    댓글 쓰기
  7. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Screws: 7 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Screws: 7 단계, 이미지 2개 중 2개
    • Remove the 3 mm Phillips screw located on the side of the bottom left-hand corner of the phone.
    • Remove the 3 mm Phillips screw located on the top right-hand corner of the phone.
    • Do not remove any of the screws located on the actual circuit boards.
    댓글 쓰기
  8. HTC myTouch 3G Glass Screen/LED Display Replacement, Separate the Circuit Board: 8 단계, 이미지 3개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement, Separate the Circuit Board: 8 단계, 이미지 3개 중 2개 HTC myTouch 3G Glass Screen/LED Display Replacement, Separate the Circuit Board: 8 단계, 이미지 3개 중 3개
    • Place a finger between the circuit board and front cover, and lift the circuit board gently.
    • Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
    • Finish separating the circuit board from the front panel.
    댓글 쓰기
  9. HTC myTouch 3G Glass Screen/LED Display Replacement, Glass Screen/LED Display: 9 단계, 이미지 1개 중 1개
    • After following the prerequisite guide listed above, the phone should have the circuit board housing group on one piece.
    • The front cover and screen of the phone should be located on the other piece.
    댓글 쓰기
  10. HTC myTouch 3G Glass Screen/LED Display Replacement: 10 단계, 이미지 2개 중 1개 HTC myTouch 3G Glass Screen/LED Display Replacement: 10 단계, 이미지 2개 중 2개
    • Place a finger on the front side of the screen, and push up as indicated.
    • Carefully grab onto the sides of the LCD and glass screen.
    • Continue to angle the LCD and glass screen further up.
    댓글 쓰기
  11. HTC myTouch 3G Glass Screen/LED Display Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully lift the screen away from the front cover.
    • The adhesive should be easy to separate while separating the front cover from the screen.
    댓글 쓰기
  12. HTC myTouch 3G Glass Screen/LED Display Replacement: 12 단계, 이미지 1개 중 1개
    • Change old LCD and glass digitizer with a replacement.
    • The LCD and glass digitizer can be separated by disconnecting the ribbon cable, and separating the layer of the LCD from the glass screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Tony Tran
회원 가입일: 09/25/12
381 평판
안내서 3개를 작성함
Cal Poly, Team 2-9, Propen Fall 2012 Cal Poly, Team 2-9, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G9
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 3,224
