주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HVAC Filter Replacement
필요한 것
  1. HVAC Filter Replacement, Filter: 1 단계, 이미지 1개 중 1개
    • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
    댓글 쓰기
  2. HVAC Filter Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
    • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
    댓글 쓰기
  3. HVAC Filter Replacement: 3 단계, 이미지 1개 중 1개
    • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
    댓글 쓰기
  4. HVAC Filter Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the vent cover to access the ventilation filter.
    댓글 쓰기
  5. HVAC Filter Replacement: 5 단계, 이미지 1개 중 1개
    • Optional: Put on a latex glove on the hand that you will use to remove the filter.
    댓글 쓰기
  6. HVAC Filter Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the filter carefully.
    • Make sure to remove it slowly so that the dust does not come of it.
    댓글 쓰기
  7. HVAC Filter Replacement: 7 단계, 이미지 1개 중 1개
    • Dispose of the old filter in a waste bin.
    댓글 쓰기
  8. HVAC Filter Replacement: 8 단계, 이미지 1개 중 1개
    • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
    • The dimensions for filters will vary depending on the dimensions of the vent.
    • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
    댓글 쓰기
  9. HVAC Filter Replacement: 9 단계, 이미지 1개 중 1개
    • Place the new filter into the vent opening. Make sure that it is facing the right direction.
    • There will be an arrow on the side of the filter showing which way to place it.
    댓글 쓰기
  10. HVAC Filter Replacement: 10 단계, 이미지 1개 중 1개
    • Place vent cover.
    댓글 쓰기
  11. HVAC Filter Replacement: 11 단계, 이미지 1개 중 1개
    • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
    • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
    • Repeat for every screw.
    댓글 쓰기
  12. HVAC Filter Replacement: 12 단계, 이미지 1개 중 1개
    • Turn on your air conditioner to make sure the filter does not move.
    • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anthony Estevez
회원 가입일: 10/20/23
67 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S2G1
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 64
전체 시간: 856
