주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hair Dryer Fan/ Motor Assembly Replacement
필요한 것
    1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: 1 단계, 이미지 2개 중 1개 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: 1 단계, 이미지 2개 중 2개
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      댓글 쓰기
    1. Hair Dryer Fan/ Motor Assembly Replacement, Grating: 2 단계, 이미지 1개 중 1개
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Hair Dryer Fan/ Motor Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      댓글 쓰기
    3. Hair Dryer Fan/ Motor Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Separate the hair dryer grating into the three pieces seen in the image.
      댓글 쓰기
    1. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: 5 단계, 이미지 1개 중 1개
      • Locate the screws on the handle and remove with a Phillips screwdriver.
      댓글 쓰기
    2. Hair Dryer Fan/ Motor Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully separate the plastic case with the Plastic Opening Tool.
      댓글 쓰기
    3. Hair Dryer Fan/ Motor Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • After removing the plastic case, locate the fan towards the back of the hair dryer.
      댓글 쓰기
    4. Hair Dryer Fan/ Motor Assembly Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
      댓글 쓰기
    5. Hair Dryer Fan/ Motor Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the screws holding the motor to the casing using a Phillips screwdriver.
      • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
      댓글 쓰기
    6. Hair Dryer Fan/ Motor Assembly Replacement: 10 단계, 이미지 1개 중 1개
      • Isolate the fan from the rest of the dryer.
      • Remove the screws holding the motor in place. Replace with the new component.
      댓글 쓰기
    7. Hair Dryer Fan/ Motor Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
      • Soldering Skills
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Mitch
회원 가입일: 10/04/12
37 평판
안내서 5개를 작성함
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 회원
CPSU-REGAN-F12S24G29
5 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 22
지난 30일: 90
전체 시간: 18,279
