주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hair Dryer Power Supply Replacement
필요한 것
  1. Hair Dryer Power Supply Replacement, Nozzle: 1 단계, 이미지 2개 중 1개 Hair Dryer Power Supply Replacement, Nozzle: 1 단계, 이미지 2개 중 2개
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
    댓글 쓰기
  2. Hair Dryer Power Supply Replacement, Grating: 2 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
    댓글 쓰기
  3. Hair Dryer Power Supply Replacement: 3 단계, 이미지 1개 중 1개
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
    댓글 쓰기
  4. Hair Dryer Power Supply Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the hair dryer grating into the three pieces seen in the image.
    댓글 쓰기
  5. Hair Dryer Power Supply Replacement, Power Supply: 5 단계, 이미지 1개 중 1개
    • Locate the screws on the handle and remove with a Phillips screwdriver
    댓글 쓰기
  6. Hair Dryer Power Supply Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully separate the plastic case with Plastic Opening Tools
    댓글 쓰기
  7. Hair Dryer Power Supply Replacement: 7 단계, 이미지 1개 중 1개
    • Your hairdryer should now be disassembled and you should easily be able to see the fan, motor, heating element cover, and internal wiring.
    댓글 쓰기
  8. Hair Dryer Power Supply Replacement: 8 단계, 이미지 1개 중 1개
    • After disassembly and isolating the button switchboard, locate the small component that is directly connected to the power cord. Desolder the wires using a desoldering wick and a soldering iron. Refer to the soldering page below.
    • Soldering Skills
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Mitch
회원 가입일: 10/04/12
37 평판
안내서 5개를 작성함
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 회원
CPSU-REGAN-F12S24G29
5 회원들
안내서 11개를 작성함
1가이드 댓글
Will this work on damaged cord near the end of hair dryer? The hair dryer is great shape just the cord that needed to be stripped to get rid of damaged part then cut then wired again.
Donna Baillod - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 27
지난 30일: 71
전체 시간: 23,138
