주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hamilton Beach 25460Z LED Replacement
필요한 것
    1. Hamilton Beach 25460Z LED Replacement, Handle: 1 단계, 이미지 2개 중 1개 Hamilton Beach 25460Z LED Replacement, Handle: 1 단계, 이미지 2개 중 2개
      • Unplug your device before proceeding with disassembly.
      • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
      • Repeat for the other washer across from the first one.
      댓글 쓰기
    2. Hamilton Beach 25460Z LED Replacement: 2 단계, 이미지 2개 중 1개 Hamilton Beach 25460Z LED Replacement: 2 단계, 이미지 2개 중 2개
      • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
      • Pull the end of the bolt out to completely remove it.
      • Repeat for the second bolt.
      댓글 쓰기
    3. Hamilton Beach 25460Z LED Replacement: 3 단계, 이미지 2개 중 1개 Hamilton Beach 25460Z LED Replacement: 3 단계, 이미지 2개 중 2개
      • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
      댓글 쓰기
    4. Hamilton Beach 25460Z LED Replacement: 4 단계, 이미지 1개 중 1개
      • Unscrew the locking knob all the way to remove it.
      댓글 쓰기
    5. Hamilton Beach 25460Z LED Replacement: 5 단계, 이미지 3개 중 1개 Hamilton Beach 25460Z LED Replacement: 5 단계, 이미지 3개 중 2개 Hamilton Beach 25460Z LED Replacement: 5 단계, 이미지 3개 중 3개
      • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
      댓글 쓰기
    1. Hamilton Beach 25460Z LED Replacement, LED: 6 단계, 이미지 1개 중 1개
      • Gently separate the heating element housing from the cooking surface by pulling up on the housing and pushing down on the surface.
      • Pulling too far or too hard can break the delicate internal wiring.
      댓글 쓰기
    2. Hamilton Beach 25460Z LED Replacement: 7 단계, 이미지 1개 중 1개
      • On the underside of the housing, use the PH2 Screwdriver to remove the single 12mm screw to disconnect the LED tray.
      • The housing can now be completely removed.
      • Place on the side for reassembly.
      댓글 쓰기
    3. Hamilton Beach 25460Z LED Replacement: 8 단계, 이미지 3개 중 1개 Hamilton Beach 25460Z LED Replacement: 8 단계, 이미지 3개 중 2개 Hamilton Beach 25460Z LED Replacement: 8 단계, 이미지 3개 중 3개
      • Using the PH2 screwdriver, remove the single 10mm screw on the circular plastic LED tray.
      • Now remove the small plastic T-shaped piece and the plastic tray completely
      댓글 쓰기
    4. Hamilton Beach 25460Z LED Replacement: 9 단계, 이미지 1개 중 1개
      • Gently pull off the translucent bulb covers
      댓글 쓰기
    5. Hamilton Beach 25460Z LED Replacement: 10 단계, 이미지 3개 중 1개 Hamilton Beach 25460Z LED Replacement: 10 단계, 이미지 3개 중 2개 Hamilton Beach 25460Z LED Replacement: 10 단계, 이미지 3개 중 3개
      • Very gently, slide the white wiring covers down to expose the wiring connectors
      댓글 쓰기
    6. Hamilton Beach 25460Z LED Replacement: 11 단계, 이미지 1개 중 1개
      • Refer to this page to brush up on your soldering skills.
      • The LED can now be removed by desoldering the connector at each wiring junction.
      • The red LED connects to the red wire (positive) and the blue wire (negative, marked in yellow.)
      • The green LED connects to the white wire (Positive) and the blue wire (negative, marked in yellow.)
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Katie Howes
회원 가입일: 02/01/15
288 평판
안내서 2개를 작성함
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G27
4 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 28
전체 시간: 1,277
