주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hamilton Beach 51101BA Motor Replacement
필요한 것
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: 1 단계, 이미지 3개 중 1개 Hamilton Beach 51101BA Motor Replacement, Rotor: 1 단계, 이미지 3개 중 2개 Hamilton Beach 51101BA Motor Replacement, Rotor: 1 단계, 이미지 3개 중 3개
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
    댓글 쓰기
  2. Hamilton Beach 51101BA Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
    댓글 쓰기
  3. Hamilton Beach 51101BA Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
    댓글 쓰기
  4. Hamilton Beach 51101BA Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
    댓글 쓰기
  5. Hamilton Beach 51101BA Motor Replacement: 5 단계, 이미지 2개 중 1개 Hamilton Beach 51101BA Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
    댓글 쓰기
  6. Hamilton Beach 51101BA Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
    댓글 쓰기
  7. Hamilton Beach 51101BA Motor Replacement, Motor: 7 단계, 이미지 2개 중 1개 Hamilton Beach 51101BA Motor Replacement, Motor: 7 단계, 이미지 2개 중 2개
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
    댓글 쓰기
  8. Hamilton Beach 51101BA Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
    댓글 쓰기
  9. Hamilton Beach 51101BA Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Cut the thin black wire from the wire cap.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andrew Huff
회원 가입일: 09/04/15
616 평판
안내서 3개를 작성함
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G5
4 회원들
안내서 6개를 작성함
2가이드 댓글
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - 답글 공유
Que tipo de motor tengo que comprar?
hugoalex521 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 69
전체 시간: 8,825
