주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hamilton Beach 70740 Power Cord Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
    1. Hamilton Beach 70740 Power Cord Replacement, Base Removal: 1 단계, 이미지 3개 중 1개 Hamilton Beach 70740 Power Cord Replacement, Base Removal: 1 단계, 이미지 3개 중 2개 Hamilton Beach 70740 Power Cord Replacement, Base Removal: 1 단계, 이미지 3개 중 3개
      • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
      댓글 쓰기
    2. Hamilton Beach 70740 Power Cord Replacement: 2 단계, 이미지 2개 중 1개 Hamilton Beach 70740 Power Cord Replacement: 2 단계, 이미지 2개 중 2개
      • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
      댓글 쓰기
    3. Hamilton Beach 70740 Power Cord Replacement: 3 단계, 이미지 1개 중 1개
      • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
      댓글 쓰기
    4. Hamilton Beach 70740 Power Cord Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the screws indicated with a screw driver.
      댓글 쓰기
    5. Hamilton Beach 70740 Power Cord Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two screws behind the knob with a screwdriver.
      댓글 쓰기
    1. Hamilton Beach 70740 Power Cord Replacement, Motor/Cord: 6 단계, 이미지 1개 중 1개
      • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
      • Note that the plastic caps are glued
      댓글 쓰기
    2. Hamilton Beach 70740 Power Cord Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the 4 screws located under the plastic caps with a screw driver.
      댓글 쓰기
    3. Hamilton Beach 70740 Power Cord Replacement: 8 단계, 이미지 2개 중 1개 Hamilton Beach 70740 Power Cord Replacement: 8 단계, 이미지 2개 중 2개
      • Lift and remove the plastic gears at the center of the device.
      • Remove any grease residue underneath the plastic gears.
      댓글 쓰기
    4. Hamilton Beach 70740 Power Cord Replacement: 9 단계, 이미지 2개 중 1개 Hamilton Beach 70740 Power Cord Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
      댓글 쓰기
    1. Hamilton Beach 70740 Power Cord Replacement, Power Cord: 10 단계, 이미지 1개 중 1개
      • Solder the highlighted section of the power cord, and undo the wiring. Using soldering wire connect a new line with the soldering iron.
      • Learn more about soldering here.
      댓글 쓰기
    2. Hamilton Beach 70740 Power Cord Replacement: 11 단계, 이미지 1개 중 1개
      • Connect the other end of your power cord to the motor terminal.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
David Gedeon
회원 가입일: 09/17/15
806 평판
안내서 6개를 작성함
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S1G1
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 20
전체 시간: 574
