주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Harman Kardon Esquire Mini External Stand Replacement
필요한 것
    1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
      • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
      • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
      댓글 쓰기
    2. Harman Kardon Esquire Mini External Stand  Replacement: 2 단계, 이미지 1개 중 1개
      • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
      • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
      • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
      댓글 쓰기
    1. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: 3 단계, 이미지 1개 중 1개
      • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
      • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
      • After the stand is removed, replace the stand with a new one.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
yousef aljeemaz
회원 가입일: 10/18/17
1,066 평판
안내서 5개를 작성함
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G9
5 회원들
안내서 50개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 32
전체 시간: 985
