주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
필요한 것
    1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: 1 단계, 이미지 3개 중 1개 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: 1 단계, 이미지 3개 중 2개 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: 1 단계, 이미지 3개 중 3개
      • Find the removable panel at the bottom of the hand.
      • Use your finger to push upwards and open the panel.
      • Slide the panel off and separate it from the hand.
      댓글 쓰기
    2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 2 단계, 이미지 2개 중 1개 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the left-most battery by pushing down on the positive end and pulling it out.
      • Repeat this for the next two batteries.
      댓글 쓰기
    1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: 3 단계, 이미지 1개 중 1개
      • Remove the screws within the gauntlet and surrounding the palm.
      댓글 쓰기
    2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 4 단계, 이미지 1개 중 1개
      • Open the gauntlet carefully, as there are wires connecting both sides.
      • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
      댓글 쓰기
    3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 5 단계, 이미지 1개 중 1개
      • To replace the LED chip, remove the screw holding the chip in place.
      댓글 쓰기
    4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 6 단계, 이미지 1개 중 1개
      • Ensure that the LED chip is in the correct area with the correct polarity.
      • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jessica
회원 가입일: 02/24/23
109 평판
안내서 1개를 작성함
Marist, Team 1-3, Chaterdon Spring 2023 Marist, Team 1-3, Chaterdon Spring 2023 회원
MARS-CHATERDON-S23S1G3
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 693
