주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Heat Gun 수리는 자사의 서비스 설명서를 사용하세요.
  1. Heat Gun Disassembly, Overall structure: 1 단계, 이미지 3개 중 1개 Heat Gun Disassembly, Overall structure: 1 단계, 이미지 3개 중 2개 Heat Gun Disassembly, Overall structure: 1 단계, 이미지 3개 중 3개
    • All screws on one side for ease of assembly
    • Wire has a stiffener for protection
    • Switch is placed on handle in an ergonomic position so that one hand operation is easy
    • The back of the handle and the back of the body are in a straight plane in order to place the gun in vertical position after operation to cool it down
    • Vents are placed in the top part to facilitate air flow
    • The product is colored in industrial orange to be easily visible and distinguishable from the work environment
    댓글 쓰기
  2. Heat Gun Disassembly, Plastic detailing: 2 단계, 이미지 3개 중 1개 Heat Gun Disassembly, Plastic detailing: 2 단계, 이미지 3개 중 2개 Heat Gun Disassembly, Plastic detailing: 2 단계, 이미지 3개 중 3개
    • All plastic detailing is made to have no overhangs
    • screwing details are used in order to locate the two half together without external jig
    • A lip joint is used in order to secure the assembly and also make it impermeable and rigid
    댓글 쓰기
  3. Heat Gun Disassembly, Electrical component placement: 3 단계, 이미지 2개 중 1개 Heat Gun Disassembly, Electrical component placement: 3 단계, 이미지 2개 중 2개
    • All electrical components are connected using connectors instead of direct soldering to facilitate easy replacement
    • The components have negative placers inbuilt in the in plastic injection mold
    • The electrical components are placed in order to prevent shorting
    댓글 쓰기
  4. Heat Gun Disassembly, Heat component placements: 4 단계, 이미지 3개 중 1개 Heat Gun Disassembly, Heat component placements: 4 단계, 이미지 3개 중 2개 Heat Gun Disassembly, Heat component placements: 4 단계, 이미지 3개 중 3개
    • All heat components are suspended in order to prevent the heated elements to come in contact with plastic parts
    • The blower chamber is designed in heat resistant pet in order to prevent it from deformation
    • The motor and the blower fan has a press fit
    댓글 쓰기
  5. Heat Gun Disassembly, Heat tube: 5 단계, 이미지 2개 중 1개 Heat Gun Disassembly, Heat tube: 5 단계, 이미지 2개 중 2개
    • The heat tube is using mica support and kapton insulation
    • The external heat tube is stainless steel to prevent degradation of the tube.
    • The heat coil is used as a resistor to step down voltage for motor and hence it has a dual perpose
    • The heat coil is made of nichrome wire.
    댓글 쓰기
  6. Heat Gun Disassembly, Detail assembly: 6 단계, 이미지 3개 중 1개 Heat Gun Disassembly, Detail assembly: 6 단계, 이미지 3개 중 2개 Heat Gun Disassembly, Detail assembly: 6 단계, 이미지 3개 중 3개
    • Minimum number of screws (variety) are used and all screws are self tapping in order to eliminate the use of nuts and loose parts.
    • Assembly has location pins to align circular parts in a fixed orientation.
    • Heat rings are used in order to over heating
    댓글 쓰기
작성자
3다른 기여자 명과 함께
varunsanghvi2000
회원 가입일: 10/23/16
192 평판
안내서 1개를 작성함
1가이드 댓글
Any idea where I can get a replacement for the plastic fan? It just fell off and melted and there doesn’t seem to be any information on the net. It’s a simple part. I’ve only used the gun a half a dozen times but it’s been years since it was purchased. Your instructions were helpful.
C Richards - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 93
전체 시간: 10,246
