주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hitachi CP-X2010N Motherboard Replacement
필요한 것
    1. Hitachi CP-X2010N  Motherboard Replacement, Top Panel: 1 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement, Top Panel: 1 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement, Top Panel: 1 단계, 이미지 3개 중 3개
      • Flip the projector upside down to expose the screws on the underside.
      댓글 쓰기
    2. Hitachi CP-X2010N  Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
      댓글 쓰기
    3. Hitachi CP-X2010N  Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Flip projector right side up and orient it so you are facing the rear panel.
      댓글 쓰기
    4. Hitachi CP-X2010N  Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 4 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
      • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
      댓글 쓰기
    5. Hitachi CP-X2010N  Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
      • Remove the panel from the body of the projector.
      댓글 쓰기
    1. Hitachi CP-X2010N  Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
      • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
      • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
      댓글 쓰기
    2. Hitachi CP-X2010N  Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
      • Move the wires for better access to the screws if needed.
      댓글 쓰기
    3. Hitachi CP-X2010N  Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the bracket that was being held by the screw.
      • Take a picture or memorize its orientation for easier reinstallation.
      댓글 쓰기
    4. Hitachi CP-X2010N  Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Pull the button array and network adapter out carefully.
      • Make sure all the wires connected to the array are unplugged.
      댓글 쓰기
    5. Hitachi CP-X2010N  Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 10 단계, 이미지 2개 중 2개
      • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
      • Keep the screw and washer in an easily accessible place.
      댓글 쓰기
    6. Hitachi CP-X2010N  Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
      댓글 쓰기
    7. Hitachi CP-X2010N  Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 12 단계, 이미지 3개 중 3개
      • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
      댓글 쓰기
    8. Hitachi CP-X2010N  Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Hitachi CP-X2010N  Motherboard Replacement: 13 단계, 이미지 3개 중 3개
      • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
      • Too much force could break the ribbon cable.
      댓글 쓰기
    9. Hitachi CP-X2010N  Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Hitachi CP-X2010N  Motherboard Replacement: 14 단계, 이미지 2개 중 2개
      • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chance Kidd
회원 가입일: 09/20/22
1,184 평판
안내서 6개를 작성함
Austin Community College, Team 9-2, Watkins Fall 2022 Austin Community College, Team 9-2, Watkins Fall 2022 회원
AUSTINCC-WATKINS-F22S9G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 18
전체 시간: 522
