주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hitachi CP-X440 Lens Replacement
필요한 것
    1. Hitachi CP-X440 Lens Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
      • Turn the projector upside down so the bottom is facing up.
      • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
      • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
      댓글 쓰기
    2. Hitachi CP-X440 Lens Replacement: 2 단계, 이미지 2개 중 1개 Hitachi CP-X440 Lens Replacement: 2 단계, 이미지 2개 중 2개
      • Flip the projector right-side up and navigate to the back panel.
      • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
      • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
      댓글 쓰기
    3. Hitachi CP-X440 Lens Replacement: 3 단계, 이미지 2개 중 1개 Hitachi CP-X440 Lens Replacement: 3 단계, 이미지 2개 중 2개
      • Now turn the projector so the front is facing you.
      • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
      댓글 쓰기
    4. Hitachi CP-X440 Lens Replacement: 4 단계, 이미지 2개 중 1개 Hitachi CP-X440 Lens Replacement: 4 단계, 이미지 2개 중 2개
      • Gently remove the cables from their white connectors on the circuit board.
      댓글 쓰기
    5. Hitachi CP-X440 Lens Replacement: 5 단계, 이미지 1개 중 1개
      • Gently pull out the three orange ribbons from their white connectors on the circuit board.
      • You can use a spudger tool to pry them out of place.
      댓글 쓰기
    6. Hitachi CP-X440 Lens Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
      댓글 쓰기
    7. Hitachi CP-X440 Lens Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the motherboard so the projector is exposed.
      댓글 쓰기
    1. Hitachi CP-X440 Lens Replacement, Lens: 8 단계, 이미지 3개 중 1개 Hitachi CP-X440 Lens Replacement, Lens: 8 단계, 이미지 3개 중 2개 Hitachi CP-X440 Lens Replacement, Lens: 8 단계, 이미지 3개 중 3개
      • As you look at the the device overhead, you will see three pieces of orange ribbon.
      • Attached to the orange ribbon will be a stabilizer over the lamp.
      • On each side, unscrew the two 1 cm screws with a Phillips #0 Screwdriver.
      • Then remove the piece holding the orange ribbons, called the stabilizer from this point on.
      댓글 쓰기
    2. Hitachi CP-X440 Lens Replacement: 9 단계, 이미지 3개 중 1개 Hitachi CP-X440 Lens Replacement: 9 단계, 이미지 3개 중 2개 Hitachi CP-X440 Lens Replacement: 9 단계, 이미지 3개 중 3개
      • Once the stabilizer is removed, set it to the side.
      • Use a Phillips #0 screwdriver to remove the two 1 cm screws on both sides of the lens.
      • The lens element should be easily lifted out of the device.
      댓글 쓰기
    3. Hitachi CP-X440 Lens Replacement: 10 단계, 이미지 2개 중 1개 Hitachi CP-X440 Lens Replacement: 10 단계, 이미지 2개 중 2개
      • Once the lens element is safely removed, you will see 4 tiny 1/2 centimeter screws surrounding the lens.
      • Use a Phillips #000 screwdriver to unscrew each screw. This will allow you to easily remove the lens.
      댓글 쓰기
    4. Hitachi CP-X440 Lens Replacement: 11 단계, 이미지 3개 중 1개 Hitachi CP-X440 Lens Replacement: 11 단계, 이미지 3개 중 2개 Hitachi CP-X440 Lens Replacement: 11 단계, 이미지 3개 중 3개
      • Once the lens is safely removed, turn it face up.
      댓글 쓰기
    5. Hitachi CP-X440 Lens Replacement: 12 단계, 이미지 2개 중 1개 Hitachi CP-X440 Lens Replacement: 12 단계, 이미지 2개 중 2개
      • Begin to gently unscrew the lens by hand, being mindful of light pressure.
      • After a few turns, the lens should be easily removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Harper Hollon
회원 가입일: 03/21/22
238 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 25
전체 시간: 415
