주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hitachi CP-X440 Sensor Replacement
필요한 것
  1. Hitachi CP-X440 Sensor Replacement, Sensor: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the six 2 cm screws from the bottom of the case.
    댓글 쓰기
  2. Hitachi CP-X440 Sensor Replacement: 2 단계, 이미지 2개 중 1개 Hitachi CP-X440 Sensor Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the projector back upright and place the back of projector towards you. Unscrew the 3 screws circled in the back with your Phillips #1 Screwdriver. Each screw is 1 cm in length.
    • Then unscrew the two silver, 1 cm screws on the light switch panel with a Phillips #1 Screwdriver
    댓글 쓰기
  3. Hitachi CP-X440 Sensor Replacement: 3 단계, 이미지 3개 중 1개 Hitachi CP-X440 Sensor Replacement: 3 단계, 이미지 3개 중 2개 Hitachi CP-X440 Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • You will now be able to pop the top of the projector off.
    • To uncollapse the projector top fully from the projector, you can pull the black cord from the white holder near the lens, circled in red and orange.
    • With front of projector now facing you, the sensor can be found on the left of the lens.
    댓글 쓰기
  4. Hitachi CP-X440 Sensor Replacement: 4 단계, 이미지 2개 중 1개 Hitachi CP-X440 Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • The sensor will be held into the projector by a silver screw on the lower left side of lens. This single 2 mm screw will need to be unscrewed and removed. This will allow you to remove the sensor piece completely out of the projector.
    • You now will remove the sensor piece completely.
    댓글 쓰기
  5. Hitachi CP-X440 Sensor Replacement: 5 단계, 이미지 3개 중 1개 Hitachi CP-X440 Sensor Replacement: 5 단계, 이미지 3개 중 2개 Hitachi CP-X440 Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • To get the sensor piece alone, you will unscrew the single 3 mm silver screw.
    • Once this screw in the sensor piece is removed, the sensor piece will be alone and can be replaced with your new one.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Natalie Safron
회원 가입일: 03/21/22
221 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 371
