주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Holmes HEH8031 Control Buttons Replacement
필요한 것
    1. Holmes HEH8031 Control Buttons Replacement, Housing: 1 단계, 이미지 1개 중 1개
      • Ensure the device is unplugged from the wall outlet.
      댓글 쓰기
    2. Holmes HEH8031 Control Buttons Replacement: 2 단계, 이미지 1개 중 1개
      • Remove eight 12-mm Phillips #2 screws from the back cover.
      댓글 쓰기
    3. Holmes HEH8031 Control Buttons Replacement: 3 단계, 이미지 2개 중 1개 Holmes HEH8031 Control Buttons Replacement: 3 단계, 이미지 2개 중 2개
      • Turn heater over so the controls are facing up.
      • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
      • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
      댓글 쓰기
    1. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: 4 단계, 이미지 1개 중 1개
      • Remove four 12mm Phillips #2 screws from the circuit board.
      댓글 쓰기
    1. Holmes HEH8031 Control Buttons Replacement, Control Buttons: 5 단계, 이미지 3개 중 1개 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 5 단계, 이미지 3개 중 2개 Holmes HEH8031 Control Buttons Replacement, Control Buttons: 5 단계, 이미지 3개 중 3개
      • Remove the two Phillips #2 12mm screws from the button retainer.
      • Lift the button retainer off.
      • Remove the interconnected buttons.
      • If the buttons are broken, replace them.
      • If the buttons are sticking, clean them in warm soapy water and allow to dry.
      댓글 쓰기
    2. Holmes HEH8031 Control Buttons Replacement: 6 단계, 이미지 3개 중 1개 Holmes HEH8031 Control Buttons Replacement: 6 단계, 이미지 3개 중 2개 Holmes HEH8031 Control Buttons Replacement: 6 단계, 이미지 3개 중 3개
      • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
      • Remove the black plastic bracket out through the front of the heater housing.
      • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
      • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
      • If the clear window was dirty, clean it in warm soapy water and allow to dry.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chris Shaffer
회원 가입일: 10/12/16
255 평판
안내서 2개를 작성함
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 846
