주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Honda CSC29 Brushes Replacement
필요한 것
    1. Honda CSC29 Brushes Replacement, Alternator Front Cover: 1 단계, 이미지 3개 중 1개 Honda CSC29 Brushes Replacement, Alternator Front Cover: 1 단계, 이미지 3개 중 2개 Honda CSC29 Brushes Replacement, Alternator Front Cover: 1 단계, 이미지 3개 중 3개
      • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
      • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
      • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
      댓글 쓰기
    2. Honda CSC29 Brushes Replacement: 2 단계, 이미지 3개 중 1개 Honda CSC29 Brushes Replacement: 2 단계, 이미지 3개 중 2개 Honda CSC29 Brushes Replacement: 2 단계, 이미지 3개 중 3개
      • Pull cover off the body of the alternator
      • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
      댓글 쓰기
    1. Honda CSC29 Brushes Replacement, Brushes: 3 단계, 이미지 3개 중 1개 Honda CSC29 Brushes Replacement, Brushes: 3 단계, 이미지 3개 중 2개 Honda CSC29 Brushes Replacement, Brushes: 3 단계, 이미지 3개 중 3개
      • You should now be able to see the recifier assembly, the brushes are located in the middle of the recifier assembly.
      • Remove the brush assembly by unscrewing 2, 6mm center screws using a #2 Phillips head screw driver
      댓글 쓰기
    2. Honda CSC29 Brushes Replacement: 4 단계, 이미지 3개 중 1개 Honda CSC29 Brushes Replacement: 4 단계, 이미지 3개 중 2개 Honda CSC29 Brushes Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the brush assembly by pulling it out.
      댓글 쓰기
    3. Honda CSC29 Brushes Replacement: 5 단계, 이미지 1개 중 1개
      • Inspect the brushes. If they are scored and not smooth you will need to replace the entire assembly.
      • When reinserting the brushes, make sure the springs keep the brushes in contact with the stator.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Raymond Akagi
회원 가입일: 04/11/16
238 평판
안내서 1개를 작성함
Cal Poly, Team 25-1, Maness Spring 2016 Cal Poly, Team 25-1, Maness Spring 2016 회원
CPSU-MANESS-S16S25G1
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 1,866
