주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hot Tools HPK12 Control Assembly Replacement
필요한 것
    1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 1 단계, 이미지 3개 중 1개 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 1 단계, 이미지 3개 중 2개 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: 1 단계, 이미지 3개 중 3개
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      댓글 쓰기
    2. Hot Tools HPK12 Control Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Use the metal spudger to push the center pin through to the other side.
      댓글 쓰기
    3. Hot Tools HPK12 Control Assembly Replacement: 3 단계, 이미지 2개 중 1개 Hot Tools HPK12 Control Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      댓글 쓰기
    4. Hot Tools HPK12 Control Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      댓글 쓰기
    5. Hot Tools HPK12 Control Assembly Replacement: 5 단계, 이미지 3개 중 1개 Hot Tools HPK12 Control Assembly Replacement: 5 단계, 이미지 3개 중 2개 Hot Tools HPK12 Control Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      댓글 쓰기
    6. Hot Tools HPK12 Control Assembly Replacement: 6 단계, 이미지 3개 중 1개 Hot Tools HPK12 Control Assembly Replacement: 6 단계, 이미지 3개 중 2개 Hot Tools HPK12 Control Assembly Replacement: 6 단계, 이미지 3개 중 3개
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Aaron Whitlock
회원 가입일: 10/24/16
249 평판
안내서 2개를 작성함
IUPUI, Team 3-4, Baechle Fall 2016 IUPUI, Team 3-4, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 34
전체 시간: 3,221
