주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hott T725-8G Battery Replacement
필요한 것
    1. Hott T725-8G Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
      댓글 쓰기
    2. Hott T725-8G Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
      • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
      댓글 쓰기
    3. Hott T725-8G Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully dislodge the speaker from the back panel.
      댓글 쓰기
    1. Hott T725-8G Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
      댓글 쓰기
    2. Hott T725-8G Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Use your fingers to separate the ribbon wire from the battery and the back of the display.
      댓글 쓰기
    3. Hott T725-8G Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
      댓글 쓰기
    4. Hott T725-8G Battery Replacement: 7 단계, 이미지 1개 중 1개
      • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
      댓글 쓰기
    5. Hott T725-8G Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
      • Avoid using metal when working with batteries.
      • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
      댓글 쓰기
    6. Hott T725-8G Battery Replacement: 9 단계, 이미지 1개 중 1개
      • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Emma Carroll
회원 가입일: 10/20/16
220 평판
안내서 5개를 작성함
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G2
3 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 689
