주요 콘텐츠로 건너뛰기
Hott T725-8G Screen/Display Replacement
필요한 것
  1. Hott T725-8G Screen/Display Replacement, Screen/Display: 1 단계, 이미지 1/1
    • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
  2. Hott T725-8G Screen/Display Replacement: 2 단계, 이미지 1/1
    • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
  3. Hott T725-8G Screen/Display Replacement: 3 단계, 이미지 1/1
    • Dislodge the sensor from the front panel.
  4. Hott T725-8G Screen/Display Replacement: 4 단계, 이미지 1/2 Hott T725-8G Screen/Display Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
  5. Hott T725-8G Screen/Display Replacement: 5 단계, 이미지 1/3 Hott T725-8G Screen/Display Replacement: 5 단계, 이미지 2/3 Hott T725-8G Screen/Display Replacement: 5 단계, 이미지 3/3
    • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
  6. Hott T725-8G Screen/Display Replacement: 6 단계, 이미지 1/1
    • Follow the guide to remove the motherboard from the back of the display.
  7. Hott T725-8G Screen/Display Replacement: 7 단계, 이미지 1/1
    • Follow the guide to remove the battery from the back of the display.
  8. Hott T725-8G Screen/Display Replacement: 8 단계, 이미지 1/1
    • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
  9. Hott T725-8G Screen/Display Replacement: 9 단계, 이미지 1/1
    • Remove Digitizer Panel from the front panel.
  10. Hott T725-8G Screen/Display Replacement: 10 단계, 이미지 1/1
    • Remove the LCD 5-Point Touch Screen from the display case.
  11. Hott T725-8G Screen/Display Replacement: 11 단계, 이미지 1/1
    • Remove the display from the plastic casing. The screen is now ready for replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Emma Carroll
회원 가입일: 10/20/16
193 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G2
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 320
