주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover 1 Eclipse Motherboard Replacement
필요한 것
  1. Hover 1 Eclipse Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Hover 1 Eclipse Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Hover 1 Eclipse Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
    • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
    • Remove the right side bottom shell piece.
    댓글 쓰기
  2. Hover 1 Eclipse Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Hover 1 Eclipse Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Hover 1 Eclipse Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom left shell piece.
    댓글 쓰기
  3. Hover 1 Eclipse Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
    댓글 쓰기
  4. Hover 1 Eclipse Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Hover 1 Eclipse Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Hover 1 Eclipse Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Unplug the yellow tipped plug attached to the red and black cords.
    • Unplug the black headers attached to the white, skinny cord.
    • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
    댓글 쓰기
  5. Hover 1 Eclipse Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Hover 1 Eclipse Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the white header attached to the pink and white cord.
    • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
    • Repeat steps 3 and 4 on the other side.
    댓글 쓰기
  6. Hover 1 Eclipse Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • You have now removed the motherboards from both sides.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Mina Dedijer
회원 가입일: 10/10/19
548 평판
안내서 4개를 작성함
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S12G4
4 회원들
안내서 5개를 작성함
7가이드 댓글
Can you please drop links to purchase the 2 motherboards?
Frank - 답글 공유
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - 답글 공유
We’re do you get the boards at I really need them
Ashton Mcalvain - 답글 공유
We’re do get the boards?
Hector Ortiz - 답글 공유
Any idea where to buy parts and the price?
william bowen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 31
전체 시간: 2,617
