주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover 1 Eclipse Shell Replacement
필요한 것
  1. Hover 1 Eclipse Shell Replacement, Shell: 1 단계, 이미지 3개 중 1개 Hover 1 Eclipse Shell Replacement, Shell: 1 단계, 이미지 3개 중 2개 Hover 1 Eclipse Shell Replacement, Shell: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece.
    • Be cautious of the wires connecting the plug side shell piece to the body. Do not pull the piece off until these wires have been disconnected in the following step.
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the remaining bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the remaining side bottom shell piece.
    • Remove final bottom shell piece
    댓글 쓰기
  2. Hover 1 Eclipse Shell Replacement: 2 단계, 이미지 3개 중 1개 Hover 1 Eclipse Shell Replacement: 2 단계, 이미지 3개 중 2개 Hover 1 Eclipse Shell Replacement: 2 단계, 이미지 3개 중 3개
    • On the bottom plug side shell pieces, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom plug side shell piece.
    댓글 쓰기
  3. Hover 1 Eclipse Shell Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the yellow tipped plug attached to the red and black cord on the non-battery side.
    댓글 쓰기
  4. Hover 1 Eclipse Shell Replacement: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #1 Screwdriver, remove the twelve 11mm and 13mm screws that line the bottom inside of the battery side of the Hover-1 Eclipse.
    • The screw placement is mirrored on the other side
    • Repeat these steps for the left inside of the Hover-1 Eclipse.
    댓글 쓰기
  5. Hover 1 Eclipse Shell Replacement: 5 단계, 이미지 3개 중 1개 Hover 1 Eclipse Shell Replacement: 5 단계, 이미지 3개 중 2개 Hover 1 Eclipse Shell Replacement: 5 단계, 이미지 3개 중 3개
    • Push down the shell and LED light near the center of the board as shown.
    • In the newly exposed area, there will be an 11mm screw holding in the wire that connects to the LED light of the frame. Remove this screw.
    • Now separate the light from the shell and board.
    • Repeat this for the other 3 lights.
    댓글 쓰기
  6. Hover 1 Eclipse Shell Replacement: 6 단계, 이미지 2개 중 1개 Hover 1 Eclipse Shell Replacement: 6 단계, 이미지 2개 중 2개
    • Follow the rainbow cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
    • The cord is a bundle of multicolored wires sheathed in black, halfway down.
    • Follow the black and blue cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
    • Repeat for the top right shell piece.
    • Remove both shell pieces.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Stone Burgan
회원 가입일: 10/10/19
133 평판
안내서 1개를 작성함
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S12G4
4 회원들
안내서 5개를 작성함
1가이드 댓글
Where can I buy the shell please help me
luke - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 32
전체 시간: 1,470
