주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Coast Power Button Spring Replacement
필요한 것
    1. Hover-1 Coast Power Button Spring Replacement, Board Battery: 1 단계, 이미지 3개 중 1개 Hover-1 Coast Power Button Spring Replacement, Board Battery: 1 단계, 이미지 3개 중 2개 Hover-1 Coast Power Button Spring Replacement, Board Battery: 1 단계, 이미지 3개 중 3개
      • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
      • Using a pick tool, puncture the grip tape and expose the screws.
      • Loosen all four 1" screws using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Hover-1 Coast Power Button Spring Replacement: 2 단계, 이미지 3개 중 1개 Hover-1 Coast Power Button Spring Replacement: 2 단계, 이미지 3개 중 2개 Hover-1 Coast Power Button Spring Replacement: 2 단계, 이미지 3개 중 3개
      • Now pull the black protective cover off the board.
      • Locate the battery.
      댓글 쓰기
    3. Hover-1 Coast Power Button Spring Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Coast Power Button Spring Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Coast Power Button Spring Replacement: 3 단계, 이미지 3개 중 3개
      • The battery is connected by these two sets of wires.
      • Remove the yellow wire first by pulling the two wires gently in opposite directions.
      • Now pull apart the black wire by gently pulling the two wires in opposite directions.
      댓글 쓰기
    4. Hover-1 Coast Power Button Spring Replacement: 4 단계, 이미지 3개 중 1개 Hover-1 Coast Power Button Spring Replacement: 4 단계, 이미지 3개 중 2개 Hover-1 Coast Power Button Spring Replacement: 4 단계, 이미지 3개 중 3개
      • Once the battery has been disconnected, gently pry the battery upward.
      • It is important to use a plastic opening tool to avoid puncturing the battery.
      • Once the battery is freed, remove it with your hands.
      • The battery is glued to the case and will require some effort to remove.
      댓글 쓰기
    1. Hover-1 Coast Power Button Spring Replacement, Power Button Spring: 5 단계, 이미지 3개 중 1개 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: 5 단계, 이미지 3개 중 2개 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: 5 단계, 이미지 3개 중 3개
      • Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
      댓글 쓰기
    2. Hover-1 Coast Power Button Spring Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Coast Power Button Spring Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the unwanted spring and place your new spring back into the hole.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jace Oppenlander
회원 가입일: 10/04/18
569 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 35
전체 시간: 774
