주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 H1 Battery Replacement
필요한 것
  1. Hover-1 H1 Battery Replacement, Bottom Shell: 1 단계, 이미지 1개 중 1개
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    댓글 쓰기
  2. Hover-1 H1 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    댓글 쓰기
  3. Hover-1 H1 Battery Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 H1 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    댓글 쓰기
  4. Hover-1 H1 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the battery by pulling gently on both sides of the orange connector.
    댓글 쓰기
  5. Hover-1 H1 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
    댓글 쓰기
  6. Hover-1 H1 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Aaron Teh
회원 가입일: 10/08/18
491 평판
안내서 2개를 작성함
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 9개를 작성함
15가이드 댓글
The stickers were the trick. I didn’t see them!
Daniel D - 답글 공유
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - 답글 공유
Where do I get another battery to replace it???
Tony Pate - 답글 공유
That's the question I can't seem to find the answer to
Darin - 답글 공유
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 110
전체 시간: 13,641
