주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 H1 Shell Replacement
필요한 것
    1. Hover-1 H1 Shell Replacement, Bottom Shell: 1 단계, 이미지 1개 중 1개
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      댓글 쓰기
    2. Hover-1 H1 Shell Replacement: 2 단계, 이미지 1개 중 1개
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      댓글 쓰기
    3. Hover-1 H1 Shell Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 H1 Shell Replacement: 3 단계, 이미지 2개 중 2개
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      댓글 쓰기
    4. Hover-1 H1 Shell Replacement: 4 단계, 이미지 1개 중 1개
      • Unplug the battery by pulling gently on both sides of the orange connector.
      댓글 쓰기
    1. Hover-1 H1 Shell Replacement, LED Headlights: 5 단계, 이미지 1개 중 1개
      • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
      댓글 쓰기
    2. Hover-1 H1 Shell Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
      댓글 쓰기
    3. Hover-1 H1 Shell Replacement: 7 단계, 이미지 1개 중 1개
      • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
      • Remove the horizontal light by using your fingers to pull the light up out of the shell.
      댓글 쓰기
    1. Hover-1 H1 Shell Replacement, Charging Port: 8 단계, 이미지 2개 중 1개 Hover-1 H1 Shell Replacement, Charging Port: 8 단계, 이미지 2개 중 2개
      • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
      • Be careful to not damage the wires or connector when removing the glue.
      댓글 쓰기
    2. Hover-1 H1 Shell Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
      댓글 쓰기
    3. Hover-1 H1 Shell Replacement: 10 단계, 이미지 2개 중 1개 Hover-1 H1 Shell Replacement: 10 단계, 이미지 2개 중 2개
      • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
      • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
      댓글 쓰기
    4. Hover-1 H1 Shell Replacement: 11 단계, 이미지 2개 중 1개 Hover-1 H1 Shell Replacement: 11 단계, 이미지 2개 중 2개
      • Pull the charging port to the left through the shell.
      댓글 쓰기
    1. Hover-1 H1 Shell Replacement, Power Button: 12 단계, 이미지 1개 중 1개
      • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
      • Pull the cable through the center section of the hoverboard.
      • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
      댓글 쓰기
    2. Hover-1 H1 Shell Replacement: 13 단계, 이미지 2개 중 1개 Hover-1 H1 Shell Replacement: 13 단계, 이미지 2개 중 2개
      • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
      댓글 쓰기
    3. Hover-1 H1 Shell Replacement: 14 단계, 이미지 1개 중 1개
      • Pull the power button through the hole in the shell.
      댓글 쓰기
    1. Hover-1 H1 Shell Replacement, Shell: 15 단계, 이미지 3개 중 1개 Hover-1 H1 Shell Replacement, Shell: 15 단계, 이미지 3개 중 2개 Hover-1 H1 Shell Replacement, Shell: 15 단계, 이미지 3개 중 3개
      • Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
      • Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
      댓글 쓰기
    2. Hover-1 H1 Shell Replacement: 16 단계, 이미지 1개 중 1개
      • Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
      댓글 쓰기
    3. Hover-1 H1 Shell Replacement: 17 단계, 이미지 1개 중 1개
      • Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
      • Repeat for the left side of the shell.
      댓글 쓰기
    4. Hover-1 H1 Shell Replacement: 18 단계, 이미지 1개 중 1개
      • Lift the shell to remove it from the chassis.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sara Passantino
회원 가입일: 10/08/18
347 평판
안내서 2개를 작성함
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 1,763
