주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Liberty Battery Replacement
필요한 것
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Hover-1 Liberty Battery Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    댓글 쓰기
  2. Hover-1 Liberty Battery Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Liberty Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    댓글 쓰기
  3. Hover-1 Liberty Battery Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Liberty Battery Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Liberty Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    댓글 쓰기
  4. Hover-1 Liberty Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 Hover-1 Liberty Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
    댓글 쓰기
  5. Hover-1 Liberty Battery Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Liberty Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
    댓글 쓰기
  6. Hover-1 Liberty Battery Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Liberty Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
    댓글 쓰기
  7. Hover-1 Liberty Battery Replacement: 7 단계, 이미지 3개 중 1개 Hover-1 Liberty Battery Replacement: 7 단계, 이미지 3개 중 2개 Hover-1 Liberty Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Patrick Bacon
회원 가입일: 10/08/18
438 평판
안내서 2개를 작성함
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 회원
CPSU-WHITE-F18S13G2
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 54
전체 시간: 3,282
