주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Liberty Bottom Cover Replacement
필요한 것
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    댓글 쓰기
  2. Hover-1 Liberty Bottom Cover Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Liberty Bottom Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    댓글 쓰기
  3. Hover-1 Liberty Bottom Cover Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Liberty Bottom Cover Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Liberty Bottom Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Patrick Bacon
회원 가입일: 10/08/18
438 평판
안내서 2개를 작성함
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 회원
CPSU-WHITE-F18S13G2
3 회원들
안내서 4개를 작성함
2가이드 댓글
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - 답글 공유
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 50
전체 시간: 3,675
