주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Liberty Gyroscope Sensor Boards Replacement
필요한 것
    1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
      • Flip the hoverboard over so the labels are facing upwards.
      • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
      댓글 쓰기
    2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the bottom cover by lifting it away from the hoverboard.
      • The cover on the side without the battery has two wires connecting the power button and charging port.
      댓글 쓰기
    3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 3 단계, 이미지 3개 중 3개
      • Remove one connector from the non-battery side circuit board.
      • Remove the next connector from the non-battery side circuit board.
      • To remove the connectors, pinch the plug and pull away from the circuit board.
      댓글 쓰기
    1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: 4 단계, 이미지 1개 중 1개
      • Place the hoverboard so the sensor boards face you.
      댓글 쓰기
    2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 5 단계, 이미지 2개 중 2개
      • Remove battery connector by pulling it apart.
      • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
      • Disconnect the colored wires by pulling them apart.
      • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
      댓글 쓰기
    3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
      • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
      댓글 쓰기
    4. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the four 10mm screws with a Phillips #1 screwdriver.
      댓글 쓰기
    5. Hover-1 Liberty Gyroscope Sensor Boards Replacement: 8 단계, 이미지 2개 중 1개 Hover-1 Liberty Gyroscope Sensor Boards Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the sensor board by lifting it away from the hoverboard.
      • Repeat steps 4-8 to remove the sensor board from the other side.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Eduardo Miranda
회원 가입일: 10/08/18
355 평판
안내서 2개를 작성함
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 회원
CPSU-WHITE-F18S13G2
3 회원들
안내서 4개를 작성함
9가이드 댓글
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - 답글 공유
Where do you get replacement board?
Tim Sole - 답글 공유
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - 답글 공유
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - 답글 공유
Where do you get circuit board from.
markrichardowen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 46
전체 시간: 10,289
