소개
This guide for the Hover-1 Maverick guides users in replacing the motherboard in their device. The motherboard is crucial within the hoverboard. It controls all functions and acts as a medium for communication between parts in the device. Symptoms of having a faulty motherboard include the device being unable to balance, unable to hold a charge, has flashing lights, or has trouble powering on. Users need to disconnect the battery and the wires in order to replace the motherboard.
필요한 것
*Using a 15mm Phillips screwdriver remove the 20 #1 screws from the shell of the hoverboard.
Open the shell.
다른 2명이 해당 안내서를 완성하였습니다.
Make sure you have the replacement parts before you go taking it apart first!
jeremiahthefixer - 답글
