주요 콘텐츠로 건너뛰기
Hover-1 Maverick Motherboard Replacement
Cassandra Aarrestad
Cassandra Aarrestad5 다른 기여자
최종 수정일 February 24, 2025
20 분
쉬움
This guide for the Hover-1 Maverick guides users in replacing the motherboard in their device. The motherboard is crucial within the hoverboard. It controls all functions and acts as a medium for communication between parts in the device. Symptoms of having a faulty motherboard include the device being unable to balance, unable to hold a charge, has flashing lights, or has trouble powering on. Users need to disconnect the battery and the wires in order to replace the motherboard.
필요한 것
도구
  1. Hover-1 Maverick Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Hover-1 Maverick Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Hover-1 Maverick Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • *Using a 15mm Phillips screwdriver remove the 20 #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
    Make sure you have the replacement parts before you go taking it apart first!
    jeremiahthefixer - 답글
    • Turn off hoverboard.
  2. Hover-1 Maverick Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 Maverick Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Hover-1 Maverick Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Maverick Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cassandra Aarrestad
회원 가입일: 01/23/20
627 평판
안내서 4개를 작성함
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 회원
CPSU-PATON-S20S7G2
3 회원들
안내서 5개를 작성함
댓글 한 개
Where is the parts to replace them when I get them out? You failed!
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 28
전체 시간: 2,556
