주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Nomad Battery Replacement
필요한 것
  1. Hover-1 Nomad Battery Replacement, Outer Shell: 1 단계, 이미지 3개 중 1개 Hover-1 Nomad Battery Replacement, Outer Shell: 1 단계, 이미지 3개 중 2개 Hover-1 Nomad Battery Replacement, Outer Shell: 1 단계, 이미지 3개 중 3개
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
    댓글 쓰기
  2. Hover-1 Nomad Battery Replacement: 2 단계, 이미지 3개 중 1개 Hover-1 Nomad Battery Replacement: 2 단계, 이미지 3개 중 2개 Hover-1 Nomad Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
    댓글 쓰기
  3. Hover-1 Nomad Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
    댓글 쓰기
  4. Hover-1 Nomad Battery Replacement: 4 단계, 이미지 2개 중 1개 Hover-1 Nomad Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
    댓글 쓰기
  5. Hover-1 Nomad Battery Replacement, Gyroscope Sensor Boards: 5 단계, 이미지 1개 중 1개
    • Cut the two zip ties around the bundle of wires with cutting pliers.
    • The zip tie is secured tightly around the wires. Be careful not to nick or cut any of the wires while removing the zip tie.
    • Do not puncture or cut the lithium-ion battery. Especially with a battery this large, the battery can catch fire or explode if damaged.
    댓글 쓰기
  6. Hover-1 Nomad Battery Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Nomad Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the circuit boards from the battery by pulling both battery connectors apart.
    댓글 쓰기
  7. Hover-1 Nomad Battery Replacement: 7 단계, 이미지 3개 중 1개 Hover-1 Nomad Battery Replacement: 7 단계, 이미지 3개 중 2개 Hover-1 Nomad Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the following wires connecting the circuit boards to the sensors and motors:
    • Disconnect the white connectors by pinching the tab and pulling up on the connectors.
    • Disconnect the black connectors by pulling the two sides apart.
    • Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
    댓글 쓰기
  8. Hover-1 Nomad Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the four 14mm Phillips #1 screws in the corners of each circuit board by turning the screwdriver counterclockwise.
    댓글 쓰기
  9. Hover-1 Nomad Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the circuit board by pulling it up and out of the hoverboard.
    댓글 쓰기
  10. Hover-1 Nomad Battery Replacement, Battery: 10 단계, 이미지 2개 중 1개 Hover-1 Nomad Battery Replacement, Battery: 10 단계, 이미지 2개 중 2개
    • Remove the four 15mm screws from the battery cage with a Phillips #2 screwdriver.
    댓글 쓰기
  11. Hover-1 Nomad Battery Replacement: 11 단계, 이미지 2개 중 1개 Hover-1 Nomad Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Lift the battery cage up and off the battery.
    댓글 쓰기
  12. Hover-1 Nomad Battery Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the battery by lifting it off the hoverboard frame.
    • The battery is attached to the frame with an adhesive strip. It can be removed by hand with some force.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Samuel Frazee
회원 가입일: 10/08/18
1,015 평판
안내서 7개를 작성함
Cal Poly, Team S15-G1, White Fall 2018 Cal Poly, Team S15-G1, White Fall 2018 회원
CPSU-WHITE-F18S15G1
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 53
전체 시간: 1,817
