주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Nomad Power Button Replacement
필요한 것
    1. Hover-1 Nomad Power Button Replacement, Outer Shell: 1 단계, 이미지 3개 중 1개 Hover-1 Nomad Power Button Replacement, Outer Shell: 1 단계, 이미지 3개 중 2개 Hover-1 Nomad Power Button Replacement, Outer Shell: 1 단계, 이미지 3개 중 3개
      • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
      • Remove the following twenty screws by rotating the screwdriver counterclockwise:
      • Eight 16.2mm Phillips #2 screws
      • Eight 15mm Phillips #2 screws
      • Four 19.1mm Phillips #2 screws
      • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
      • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
      댓글 쓰기
    2. Hover-1 Nomad Power Button Replacement: 2 단계, 이미지 3개 중 1개 Hover-1 Nomad Power Button Replacement: 2 단계, 이미지 3개 중 2개 Hover-1 Nomad Power Button Replacement: 2 단계, 이미지 3개 중 3개
      • Use a nylon spudger to pry the metal handle away from the outer shell.
      • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
      • Lift the hoverboard off the metal handle.
      • Repeat for the handle on the other side of the hoverboard.
      댓글 쓰기
    3. Hover-1 Nomad Power Button Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the plastic cover on each side up and away from the device.
      • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
      댓글 쓰기
    4. Hover-1 Nomad Power Button Replacement: 4 단계, 이미지 2개 중 1개 Hover-1 Nomad Power Button Replacement: 4 단계, 이미지 2개 중 2개
      • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
      • Charging port wires
      • Speaker assembly wires
      • Power button wires
      • Headlight wires
      • Only the headlight wires need to be disconnected from the other circuit board.
      • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
      댓글 쓰기
    1. Hover-1 Nomad Power Button Replacement, Power Button: 5 단계, 이미지 2개 중 1개 Hover-1 Nomad Power Button Replacement, Power Button: 5 단계, 이미지 2개 중 2개
      • Peel off the glue around the power button.
      • Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
      댓글 쓰기
    2. Hover-1 Nomad Power Button Replacement: 6 단계, 이미지 1개 중 1개
      • Feed the wire and connector through the removed nut and pull the power button out through the hole in the outer casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Samuel Frazee
회원 가입일: 10/08/18
1,015 평판
안내서 7개를 작성함
Cal Poly, Team S15-G1, White Fall 2018 Cal Poly, Team S15-G1, White Fall 2018 회원
CPSU-WHITE-F18S15G1
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 658
