주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Titan Left Gyroscope Replacement
필요한 것
    1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 1 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: 1 단계, 이미지 2개 중 2개
      • Flip the hoverboard so the bottom is facing up.
      • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
      댓글 쓰기
    2. Hover-1 Titan Left Gyroscope Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
      • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
      • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
      댓글 쓰기
    3. Hover-1 Titan Left Gyroscope Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Titan Left Gyroscope Replacement: 3 단계, 이미지 3개 중 3개
      • Grip the bottom left panel and lift up to remove.
      댓글 쓰기
    1. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 4 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: 4 단계, 이미지 2개 중 2개
      • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
      댓글 쓰기
    2. Hover-1 Titan Left Gyroscope Replacement: 5 단계, 이미지 3개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 5 단계, 이미지 3개 중 2개 Hover-1 Titan Left Gyroscope Replacement: 5 단계, 이미지 3개 중 3개
      • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
      댓글 쓰기
    3. Hover-1 Titan Left Gyroscope Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 6 단계, 이미지 2개 중 2개
      • Unplug the bottom right connector by squeezing it and pulling it away from the board.
      댓글 쓰기
    4. Hover-1 Titan Left Gyroscope Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 7 단계, 이미지 2개 중 2개
      • Unplug the light connector by squeezing it and pulling away from the board.
      댓글 쓰기
    5. Hover-1 Titan Left Gyroscope Replacement: 8 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 8 단계, 이미지 2개 중 2개
      • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
      댓글 쓰기
    6. Hover-1 Titan Left Gyroscope Replacement: 9 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 9 단계, 이미지 2개 중 2개
      • Unplug the small white connector by squeezing it and pulling away from the board.
      댓글 쓰기
    7. Hover-1 Titan Left Gyroscope Replacement: 10 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 10 단계, 이미지 2개 중 2개
      • Unplug the plug in the red connector.
      • The red plug is glued to the board, so this step will require extra force.
      댓글 쓰기
    8. Hover-1 Titan Left Gyroscope Replacement: 11 단계, 이미지 2개 중 1개 Hover-1 Titan Left Gyroscope Replacement: 11 단계, 이미지 2개 중 2개
      • Unplug the charging cable connector by squeezing it and pulling it away from the board.
      댓글 쓰기
    9. Hover-1 Titan Left Gyroscope Replacement: 12 단계, 이미지 1개 중 1개
      • Cut the cable tie.
      • Unplug the remaining wires.
      • The connectors for the remaining wires are in the rubber covers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jessica Ouyang
회원 가입일: 10/08/18
634 평판
안내서 4개를 작성함
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 10개를 작성함
2가이드 댓글
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - 답글 공유
Where do you buy the board?
eden11 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 36
전체 시간: 1,704
