주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Titan Power Button Replacement
필요한 것
    1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: 1 단계, 이미지 2개 중 1개 Hover-1 Titan Power Button Replacement, Bottom Right Panel: 1 단계, 이미지 2개 중 2개
      • Flip the hoverboard so the bottom is facing up.
      • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
      댓글 쓰기
    2. Hover-1 Titan Power Button Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Titan Power Button Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
      • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
      • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
      댓글 쓰기
    3. Hover-1 Titan Power Button Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Titan Power Button Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Titan Power Button Replacement: 3 단계, 이미지 3개 중 3개
      • Grip the bottom right panel and lift to remove it.
      댓글 쓰기
    1. Hover-1 Titan Power Button Replacement, Power Button: 4 단계, 이미지 2개 중 1개 Hover-1 Titan Power Button Replacement, Power Button: 4 단계, 이미지 2개 중 2개
      • Disconnect the battery by holding the yellow connectors and pulling apart.
      댓글 쓰기
    2. Hover-1 Titan Power Button Replacement: 5 단계, 이미지 3개 중 1개 Hover-1 Titan Power Button Replacement: 5 단계, 이미지 3개 중 2개 Hover-1 Titan Power Button Replacement: 5 단계, 이미지 3개 중 3개
      • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
      • You can also unplug the light connector to free up your work space.
      댓글 쓰기
    3. Hover-1 Titan Power Button Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Titan Power Button Replacement: 6 단계, 이미지 2개 중 2개
      • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
      댓글 쓰기
    4. Hover-1 Titan Power Button Replacement: 7 단계, 이미지 3개 중 1개 Hover-1 Titan Power Button Replacement: 7 단계, 이미지 3개 중 2개 Hover-1 Titan Power Button Replacement: 7 단계, 이미지 3개 중 3개
      • Pull the power button out of the panel.
      • Replace the power button.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Alexander Pham
회원 가입일: 10/07/18
221 평판
안내서 1개를 작성함
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 45
전체 시간: 1,061
